DISCUSSION => Swaps, Turbos, Buildups => Topic started by: Danny707 on November 06, 2008, 11:40:27 PM
Title: So lets talk cheap turbo manifold solutions.
Post by: Danny707 on November 06, 2008, 11:40:27 PM
So I've seen cutting an M50 turbo manifold to fit, but all the ebay manifolds are more expensive than an OBX one for an m42.
So the question is how hard would it be to adapt a stock manifold for a turbo, or would it not work at all?
Post by: crazzy_hippo on November 07, 2008, 11:18:43 PM
Quote from: Danny707;60139
I think its much easier to just modify a M50 turbo manifold and they are not that expensive.
http://cgi.ebay.com/ebaymotors/BMW-E36-M3-323-325-328-T3-TURBO-MANIFOLD-NEW-Stainless_W0QQcmdZViewItemQQ_trkparmsZ72Q3a543Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem140278508195QQitemZ140278508195QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/BMW-E36-All-3-0L-3-2L-92-99-Turbo-Exhaust-Manifolds_W0QQcmdZViewItemQQ_trkparmsZ72Q3a543Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem270297087745QQitemZ270297087745QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Post by: Danny707 on November 07, 2008, 11:39:49 PM
You know, funny thing is I just found the thread where he did that after I posted this thread lol.
I feel dumb.
But thats so awesome that that will work.
How's the quality on the 99 dollar units?
Good enough for 7 psi?
Post by: 1991 E30 M42 on November 08, 2008, 08:24:59 AM
you should buy a honda civic
Post by: crazzy_hippo on November 08, 2008, 08:38:45 AM
Quote from: Danny707;60193
I feel dumb.
I don't have any experience with them. However, one issue is that these manifolds are made of stainless steel which is prone to cracking (esp. the welded areas) under prolong heat cycle.
I strongly recommend you to reinforce the welded areas to reduce chances of cracking.
Post by: Danny707 on November 08, 2008, 02:09:11 PM
Quote from: 1991 E30 M42;60202
Thanks for the bump ;)
Quote from: crazzy_hippo;60203
Thanks for the help :)
Post by: 1991 E30 M42 on November 08, 2008, 09:19:42 PM
Quote from: Danny707;60227
It wasn't a bump, buy a honda civic, $500 gets you a turbo kit all day long on ebay
Post by: bearsbmw on November 08, 2008, 10:11:56 PM
Im using a M50 Manifold and a hybrid ebay turbo and I have no problems with them
Post by: Jtuner on November 26, 2008, 03:07:01 PM
Quote from: 1991 E30 M42;60251
I plan to boost my m42.. I don't know about you, but my stock m42 has more balls than any stock civic I've found.. Take the $500 turbo kit and adapt it to your bmw.... wanna dis on people's ideas and projects? go to r3v....
Post by: deekay on November 29, 2008, 03:32:14 AM
Quote from: Jtuner;61758
http://www.m42club.com/forums/showthread.php?p=59185#post59185
don't mind this guy, he's just bitter that he spent 3x the money on a 1.9l stroker and got 1/3 the power-add of a low-boost turbo setup. if he weren't so emotionally invested in the idea that what he did is "the right way" and anything else is "wrong" he'd start crying about how most of his performance comes from his weight-reduced wallet.
Post by: roundel318 on November 29, 2008, 02:34:13 PM
Perhaps the kid just likes the BMW more than a Honda :)
Post by: 1991 E30 M42 on December 02, 2008, 07:18:18 PM
I don't have problems with putting a turbo on a 318is, I actually have one in the works. It just seems to me that no one wants to do it right, all they want is cheap, and no one wants to do the research, there is plenty of information on this site regarding turbo builds. You can actually build your own equal length turbo manifold for the price of taking an ebay manifold and modifying it. you can also adjust runner lengths to help spool the turbo at a lower rpm ex: longer runners for lower rpm. You can get nice used turbos on ebay and rebuild them, its not that complicated.Down pipe is even easier, get a piece of u-bend from summit, its cheap.
Post by: dcarchitect on December 03, 2008, 05:02:41 AM
Turbo on an M42?
or 3x for a stroker motor?
there is something very wrong here, are we all so rich that we have saved up all the money we need for a very long time that we can go pissing away money we will never get back on mods which might break the rest of the car?,
How about taking your turbo or stroker money, pus all the future money for the cool-stuff we think we're going do, plus the money we are going to need to fix what's going to break,  or wear out and save it all up for just a little while, then march down to BMW and get a new 128 coupe with 230 hp and a factory warranty?
Post by: roundel318 on December 03, 2008, 02:23:58 PM
While I agree with you, there is something great about an old E30.
It's light, has little of the BS electronic crap (iDrive, countless other things) that just make things more complex. The E30 is nostalgic because it's from a time when BMW's were more simple. Besides, the second you drive a new car off the lot, you just flushed half of your money you saved up.
Post by: 1991 E30 M42 on December 04, 2008, 01:01:16 AM
3X the money LOL, so that means you can build a reliable turbo m42 , includind turbo, down pipe, exhaust, intercooler, boost piping, blow off valve, injectors, frp, and engine managment for $600? Hah funny
Post by: deekay on December 04, 2008, 01:54:32 AM
Quote from: 1991 E30 M42;62225
Quote
M44 50 over MaxSil pistons, Sealed Power rings, M44 Rods, M44 crank, Fidanza flywheel, S52 Clutch, completely rebuilt head ( new valve guides, springs, valves, valve stem seals) shaved 10 thousandths, all internals are balanced, new oil pump, pickup tube, timing chain, timing rails, new injectors, fpr, Mark D 93 octane chip, everything outside is powder coated, UUC Motorwerks Oil Center, throttle body coolant hose bypass, removed hose nest under manifold and replacing with Samco Sport silicone hoses, header wrap, Ireland engineering Urethane engine mounts, soon to have silicone radiator hoses, electric fan, mustang injectors
$300 for powder coating and you got all of the rest of that, block- and head-work included, for a grand and a half? also funny.
Post by: 1991 E30 M42 on December 04, 2008, 12:06:57 PM
E-Bay, I only spent $450 on brand new m44 rotating assembly which included MaxSil pistons and sealed power rings
Post by: Danny707 on December 04, 2008, 04:50:40 PM
Meh, I got my answer and it'll happen.
You do your thing, I'll do mine ;)
