DISCUSSION => Engine + Driveline => Topic started by: deltaneo1 on October 14, 2008, 03:32:21 AM
Title: New Lifters???????
Post by: deltaneo1 on October 14, 2008, 03:32:21 AM
I have a 1993 318i and i hear ticking at higher rpm's(starts around 1900) but really faint at idle ...  I got this car and it runs good just the noise is killing me..I dont hear it inside the car just when i roll down the window.... I know the noise is coming from the valve cover and i took it off and to adjust the valves... but there was no way to adjust them.. (not like old chevy motors)... I dont feel like replaceing everything under the hood till i get it..
     I;ve heard it all from using a better gas to ,lifters to ,oil to ,timeing chain to ,water pump to ,fuel injectors ...... what is it??? I know Almost all these cars do this but whats the sure bet on what it is?????
     Im thinking its the lifters but there is this black shroud that covers the rockers and lifters and cam... i wonder if maybe that is hitting a rocker and making that noise??? i was going to just take it out but didnt know if i should ..i think that it makes the oil splash on the cam and lubes it???
     I also tryed some of that thick ass oil thats like for motors to stop smokeing and makeing noise but didnt do anything...( and no it wasnt smokeing befor that eather). any one have any good ideas or dose it turn out that im going to have to chase down the noise peace at a time???
oh yeah the cars has 171000 k about 100000 miles
Post by: txleadfoot on October 14, 2008, 09:52:05 AM
All the M42's I've owned have had loud fuel injectors.  There's no rocker arms in an M42.  Leave the shroud installed in the valve cover.  Could be an exhaust leak at the headers?  Perhaps you can record/film the sound and post here?  A mechanic's stethoscope would be handy to locate the source of the noise as well.
Post by: kowalski on October 14, 2008, 11:38:05 AM
the lifters do just make noise when they're old and worn out. kind of an expensive repair, but do as u must.
Post by: deltaneo1 on October 14, 2008, 11:39:29 AM
Quote from: txleadfoot;58488
Its not the fuel injectors i took a wooden rod and its coming from under the valve cover..(i reved it up and it gets worse) i know it has a small leak somewhere but like i said its coming from the valve cover.. but i bet the leak dosnt help any...
Post by: deltaneo1 on October 14, 2008, 11:42:37 AM
Quote from: kowalski;58497
i looked up lifters online and there about 10-18$ depends on type.. i know i would need 16 of them but are they that hard to do???? cant you just loosen the cam and push the (Rocker type peice) to the side and pull the lifter out and then replace it???? thats if i can do it without moving the cam too much????
Post by: JP 91iS on October 14, 2008, 01:45:09 PM
Quote from: deltaneo1;58499
You should get yourself a copy of the E36 Bentley
Title: True dat.
Post by: txleadfoot on October 14, 2008, 03:02:45 PM
How's your oil pressure?
Title: Lifters DIY
Post by: txleadfoot on October 14, 2008, 03:11:38 PM
There is no "rocker type piece," dude.  There are lots of write-ups on this site for the procedure.
Here's what you'll see once the cams are out:
(http://i47.photobucket.com/albums/f164/txleadfoot/M42%20Rebuild/DSC08779.jpg)
Check your oil pressure before you get too far.
Post by: nicknikolovski on October 15, 2008, 03:50:35 AM
Hey Joe, that black thing under the valve cover - I am presuming that you are talking a the baffle - I believe it is apart of the valve cover and acts as a oil/vapour seperator so I would not remove it. Otherwise could you please post a picture of it because I am not 100% what you mean.
Post by: deltaneo1 on October 15, 2008, 04:29:59 AM
Quote from: txleadfoot;58521
ok yeah mine dosnt look like that...that looks like a duel over head cam mines a single
ill take a pic and post it.. i dont know if it makes a diff but i have a german spec bmw
Post by: deltaneo1 on October 15, 2008, 04:36:27 AM
Quote from: txleadfoot;58520
i havnt check oil presure... ill i have is the dummy gauges. what would the oil pressure show???? i was thing that maybe a lifter might be cloged so oil isnt getting on one part one part of the cam making the noise... well also oil go's through the lifter and squirts in the valve cover right???? im new to bmw and i know on old chevys thats how it works so im quessing its the same.... well if it not where does the oil come from that gos on the cam????
Post by: Cre8toR on October 15, 2008, 06:22:51 AM
Mate i had a simlar prob to what your explaining and it turned out that my exshust had a crak in it..
Post by: deltaneo1 on October 15, 2008, 09:48:18 AM
Quote from: Cre8toR;58582
So did it make any more noise when you fixed it???? I know there is a leak somewere but i dont think thats where it is comeing from ... I can hear it under the valve cover.... Im sure the leak dosnt help out with the noise i bet it makes it worse...
Title: Oil Pressure
Post by: txleadfoot on October 15, 2008, 11:39:27 AM
Sorry man, had no idea you had SOHC.  I have no idea about the inner workings of your engine.  This is the M42 club!
Quote from: deltaneo1;58577
Post by: deltaneo1 on October 15, 2008, 01:19:04 PM
Quote from: txleadfoot;58591
so thats why everyone was saing that there was no rockers.... And i thought i was going crazy looking at them and thinking to myself that it looks like rockers to me... lol ... or maybe there called something else on bmw's but on other cars there rockers... yeah i thought i had a m42 myself till someone told me its a m40 not a m42.... lol
