DISCUSSION => General Topics => Topic started by: 91 318is on October 04, 2008, 11:22:51 AM
I tried searching but came up with nothing.
I did the heater plate delete and I've been trying to bleed it for about 30 minutes and not having too much luck. When I run the heater on full hot, it's blowing cold, so I know there's air in the system. Is it better to run it with the cap off or should I put the cap on and let the system pressurized? When I leave the cap off, the temperature doesn't get too hot, but it just pumps coolant out of the overflow. When I cap it, it begins to overheat and I shut it off.
Any advice?
