DISCUSSION => General Topics => Topic started by: ducatipaso on July 13, 2008, 08:44:30 PM
Title: my power steering sings to me...
Post by: ducatipaso on July 13, 2008, 08:44:30 PM
2000-2500 rpm, wheel to right at about 2'oclock
sometimes
ooooooooooooo....
ooooooooooooooooooooooo...
almost a 440 A pitch
failing pump? the damn rack was replaced about 5 years ago and I splurged for OEM. suck. this is bad timing as my ign cyl died on the 190e.
Post by: halcron on July 13, 2008, 11:20:38 PM
Quote from: ducatipaso;53255
sometimes
ooooooooooooo....
I too have this problem. My pump gets oooo....whheeeeee....oooo when the steering wheel is at neutral. Was told the pump is failing. Now sourcing for an electric PS pump. Wanted to dump the belt driven one.
Post by: ducatipaso on July 14, 2008, 12:20:48 AM
well I guess even if it does fail, it won't be like massively catastrophic. i guess i'll start shopping around.
Post by: colin86325 on July 14, 2008, 08:56:30 AM
How's the ps fluid level?  The moan you hear can also be caused by air entering in the front seal of the pump.  You can rebuild the pump for about $30 or so.
Post by: ducatipaso on July 14, 2008, 03:51:38 PM
the fluid level is fine. in fact, there might be a smidge too much in there.
Post by: Matt-B on July 15, 2008, 01:49:18 AM
I work at a LUUUUUUbe shop man!
Post by: EN318isPDX on July 15, 2008, 10:07:43 AM
Quote from: matthew-mayhem;53308
KY or Vaseline?
Post by: ducatipaso on July 15, 2008, 10:52:53 AM
bwahahah nice one guys :: matt you keep your lube to yourself :)
Post by: EN318isPDX on July 15, 2008, 10:59:36 AM
Quote from: ducatipaso;53326
See i had no idea what matt was talkin about so i had to clown on it.. he must be higher than me!
