DISCUSSION => General Topics => Topic started by: adam12hicks on June 20, 2008, 10:28:11 AM
This was found during a stomp test. I don't notice any missing or hesitation, but I'd like to check the contacts and test a known good coil.
My problem is I'm not sure how to tell which coil is 1, 2, 3 and 4? Does anyone have a quick diagram that shows which coil is which?
Thanks!!!
There should be numbers stamped into the plastic that surrounds the coils.
Wouldn't plug number 1 be connected to coil number 1?
Now stamped numbers are handy :) Sorry I'm sure plug 1 goes to coil 1, but to be honest (and I'm not afraid to admit it) I don't know if the cylinders are 1-4 front to back or back to front, so I wanted to check to be sure before making any assumptions. I can do a lot of work on these things, but I don't do block work. I pay someone for that...
Thanks!
I believe the cylinder numbers go front to back.
