DISCUSSION => Engine + Driveline => Topic started by: Janne on June 19, 2008, 12:29:14 PM
Is that safe to remove the water cycle from that Flange? (Part number 9.)
http://www.realoem.com/bmw/showparts.do?model=BE51&mospid=47425&btnr=11_1405&hg=11&fg=40
Is this flange´s job to heat the CRANK CASE VENT VALVE?
I will connect hoses 11. and 10 straight together on coupler.
http://www.realoem.com/bmw/showparts.do?model=BE51&mospid=47425&btnr=11_1501&hg=11&fg=35
Car is E36 318is.
Yes, it is probably safe to delete that plate.
