DISCUSSION => Electrical => Topic started by: Shaunster on May 25, 2008, 06:52:04 AM
Title: Help with rear demister/defogger
Post by: Shaunster on May 25, 2008, 06:52:04 AM
Hey all, since I got my 318is I have not had the rear demister work at all. The windows are tinted so I have a feeling nothing was hooked back up after the tinting was done.
I have searched this on multiple e30 forums and I have not found an answer. Where abouts do you plug the power cable onto the rear windscreen and what does the cable look like. I would love to get a picture of this for refference.
I have had a poke around the back, and I do not see any cable that should be plugged onto the screen or a spot on the screen with any tabs/tangs to plug onto, but I could not work out how to remove the parcel shelf to get a better look.
Can someone shed some light onto this for me?
Thanks a heap,
Shaun
Post by: ak96ss on May 25, 2008, 01:45:52 PM
The connectors (there are two) for the rear window defogger are located in the lower corners of the glass, a couple of inches up from the bottom. The cable looks like this:
(http://lh3.ggpht.com/2006TopBanana/SDmCxDXleaI/AAAAAAAADaQ/4t_tDd5SKQY/s800/pb093874.jpg)
There should be a tab on each side of the glass that the black connector plugs into. If the tabs have been removed, you are pretty much out of luck. I know that it is possible to replace these tabs, but I haven't ever heard of anyone making that actually work.
To remove the parcel shelf, you have to first remove the rear seat. Then, remove the rear speakers. Then, using a wide flat bladed pry tool or screw driver, remove the covers over the seat belt winders by pushing in from the front towards the rear of the car and prying upwards. It's a little tricky, but it can be done. Once the covers are off the winders, slide them down the seat belt strap. There is a trim retainer in the middle of the parcel shelf that clips into the steel underneath, but the whole tray should pretty much just pop off from the front. You don't have to remove the seat belts, just slide the tray down where the upper rear seat was.
You can (barely) see one of the connectors in this picture, lower left corner of the glass.
(http://lh5.ggpht.com/2006TopBanana/SDmytjXlebI/AAAAAAAADaY/B3G9Wwcuz1o/s800/pb093873.jpg)
Post by: Shaunster on May 26, 2008, 03:23:32 AM
Thats perfect, I will take a look this weekend! Thanks for the excellent help.
