FAQ / REFERENCE => M42 Reference => Topic started by: Asserti on April 16, 2008, 08:09:29 AM
Title: Engine failure / timing chain slipped
Post by: Asserti on April 16, 2008, 08:09:29 AM
I'd like to know when most of the people here had their enginge broken down.
I've seen some threads about broken engines, due to the pan gasket shift and the chain skipping a tooth or two. We all know how it happens.
What I want to know is if this is mileage dependent. Also, the model year of the car can play a role.
So the question is; when did your engine die due to a timing chain slip, pan gasket shift, ... and from what year was the car.
Mine was a nov '89 with 224 000km, 139 200miles and failed due to the timing chain slipping some tooths, intake valves bent, no lose oil pan bolts tough.
Post by: batsbats on April 16, 2008, 05:01:12 PM
I'm curious about this too.
About to 100k.  I was thinking about changing the tensioner and chain within the next 10k miles or the summer, since it's about 17-18 years old.
Post by: strad on May 16, 2008, 10:51:01 PM
My motor has 202k on it.  New tensioner at about 195k (replaced original!).  No timing chain rollers in pan (last look was at 198k).  Definite signs of wear on the cam sprockets (checked at 201k or so) but no abnormal noises.  Will probably do a timing chain replacement sometime within the next year if I decide to keep the M42 between the frame rails.
Post by: pbgd3skier on June 02, 2008, 09:34:17 PM
When I got the car the engine was shot, needed head work, valves, and bottom end work.  Not sure what the PO did, no oil changes, maybe antifreeze leaked out who knows.
Read 115 miles on the odo.
1991 e30.
Bought a junk yard engine that had certain good bits (like the head) and build 1 good engine out of the bits.  Have alot of spares around from that engine too, which is good.
Post by: hoevesruperd on June 02, 2008, 10:49:26 PM
i guess it all depends on the maintenance done.
my cluster indicates 165k kms and the timing chain sprockets are already pointy.
will my new timing chain tensioner at least prevent the chain from skipping?
Post by: Asserti on June 03, 2008, 10:58:36 PM
I think as long as you don't find bits and pieces in your carter your okay...
Mine has 150k kms now and rattles from 3 to 4k rpm. Whil be revising the distribution sometime soon.
Post by: Vorpal on June 05, 2008, 09:56:26 PM
My odometer indicates 166k, but it's broken and likely has been for some time, so I put 186k+ on the poll. Still going strong, no problems besides a little lifter tick (not audible from inside the car unless the windows are rolled down and I'm driving next to something that will reflect the sound), which I understand is pretty much normal on an older engine. I pulled the valve cover and the cam sprockets still look nice and square. I dropped the lower pan and found no loose or missing bolt or even any rollers from the timing chain. Everything looks top notch! (knock on wood.) I have a new chain tensioner that I'll put in before too long, since everything else checks out.
Post by: mark_i on September 03, 2008, 10:29:10 PM
my m42 died at 206000km.
Timing chain jumped the exhaust cam sprocket by 7 teeth and bent valves.
Chain tensioner replaced at 193K which fixed the 4000 rpm rattle.
Should have replaced the chain, sprockets and guides that I bought when in Europe last year, but got I spooked by the 270Nm crankbolt removal...
April 1990 e30
Post by: KenC on September 04, 2008, 03:12:43 AM
Quote from: mark_i;55995
April 1990 e30
How did it jump?  Which sprocket did it jump on?  Mine chain is super tight.
Crankbolt removal is easy.  Just stick a pin in the flywheel to lock it, and then use a large breakerbar to remove the bolt.
Post by: cheesebox on September 04, 2008, 02:42:41 PM
Mine died at 82000 miles with a failed profile gasket. BMW confirmed it was never replaced under warranty, unlike many others. What a shame. Still it was a good opportunity to replace a few timing components and other bits and pieces.
Title: M42 timing chain
Post by: mark_i on September 05, 2008, 07:14:41 PM
Quote from: KenCopperwheat;56005
Thanks for the interest
No idea how the chain jumped the exhaust cam sprocket. This happened one morning when cranking the engine on the starter, not on load. Really nasty metal clunking sound and on removal of the rocker cover, the problem was obvious. After I returned the exhaust cam to the correct position, the engine could not be rotated clockwise without a fight and I could see the chain straining and again trying to move off the sprockets. The chain does not have any missing or damaged rollers so I guess the the guides are damaged and the bent valve stems prevent the cam from rotating in sych with the pistons.
To only way to check is to remove the timing covers and the crankbolt is the problem. I tried using a pin to bolt the flywheel  but the torque on the breaker bar was too much and the pin just bent.
I have posted in the wanted section for a replacement head.
Post by: Oversteer on September 11, 2008, 05:41:18 AM
Seems like I'm the only guy capable of breaking a M42 before the 100.000Km mark!!
It was years ago, a '94 E36 with just 70.000kms! I still don't know what happened, maybe very low oil level. I was just going flat out in 5th, 6000rpm plus, and the engine started to make a very hard knocking noise when I put my foot down (probably crankshaft bearings), and after a couple of miles, the engine blew!
Oil pressure warning light on, engine working on 3 cylinders, idling at around 3Krpm, big hole in the block (intake side), and a conrod missing!:D
Post by: ///m42 sport on September 18, 2008, 11:59:08 AM
280k+ miles.  Rebuilt at 180k miles due to broken chain.
Post by: raw69 on October 09, 2008, 02:28:11 AM
I had the same problem with my 93 e36 318is,due to left hand side timing chain guide completely disintigrating which caused chain to skip a few teeth on inlet sprocket :( This left inlet valves in the path of incoming pistons which bent all 8 inlet valves.My car has 200,000km and I have stripped motor / head down ready for the rebuild.
Post by: duckboy74 on December 02, 2008, 12:13:08 AM
3rd owner. No previous history known. Still running @ 240k
Post by: roundel318 on December 02, 2008, 08:46:35 AM
3rd owner, 267,000 miles. on its 2nd timing chain tensioner, original everything else :)
Post by: G-Man on December 24, 2008, 01:47:49 PM
The chain tensioner on my 91 318i broke at 129K in DEC 07 and needless to say, the engine was trashed.  I was lucky enought to score another M42 from a fellow BayE30.net member for $350 whose girlfriend had recently wrecked his 91 318is.  Before the motor went in, a new clutch was installed, all hoses under the intake manifold were replaced, new timing chain and oil pump along with a new chain tensioner.  I hope to go for another 200K with this engine.
G-Man
91 318i sedan
89 325i 5 speed sedan (totaled last week, RIP)
86 325 eta 5 speed coupe (youngest daughters DD)
81 E12 528iA (Euro spec)
74 2002tii 5 speed, lsd, (many other mods)
79 E3 2800 4 speed (Euro spec)
96 4Runner 4cyl, 5 speed, (parts hauler)
Post by: Kingsly on December 24, 2008, 02:17:33 PM
189,000, no major work done, still running smooth and pulling strong. Just replaced the original chain tensioner (which was seized at about half extension) five days ago. Plan on flushing the oil and dropping the pan to check for bolts/gasket problems sometime after the holidays. :)
Post by: Deftones on December 25, 2008, 05:32:58 AM
my e36 has over 315000 km and still runs well; the e30 has "only" 180000 so i think his life is so long!
Post by: DesktopDave on February 10, 2011, 04:51:07 PM
Thread back from the dead!  I'm researching M44 upgrade parts for the M42.
Anyway, I'm running 269K miles on the original chain.  The PO's mechanic updated the guides & tensioner, so I'm likely running newer M44 parts.  Cam teeth are pointy though, so I'll be replacing them sooner or later.  No bits in the pan either, just the typical bolt impact mark on the oil pickup & mirror image on the lower pan.
Post by: B318M42W on February 10, 2011, 07:54:56 PM
still running at 315K km, went FI@6psi 2k ago and still breathing. replaced chain,sprockets, rails @ 288K.  hadrollers in the oil pan trigger the replacements
Post by: Home made iS on March 10, 2011, 04:37:55 PM
m42 still kickin at 220k kms, previous m40 lasted 400,000. then dropped 5l oil at 100kmh, smashed bearings and rods :( . made way for e36 m42 conversion, best upgrade ever.
Post by: DesktopDave on March 10, 2011, 05:13:01 PM
You upgraded an e30 M42?  I thought about the serpentine belt & electric fan bits, but did you do something else fun like enable knock sensors with the e36 DME?
Title: Engine Died
Post by: hnilsen on March 12, 2011, 06:07:23 PM
I'm at wit's end with my 1991 BMW 318i M42B18 which probably has about 200,000 miles on it. For about a year there has been a distinct rattling emanating from the upper engine, leading me to guess the problem was maybe valves, hydraulic lifters, maybe a loose timing chain...? The engine, however, seemed to run fine and since the car is so old I didn't do anything about it.
Then 2 weeks ago, I'm driving along at about 40 mph and without any big noise or fanfare, the engine just dies. Upon trying to crank it over, the very first attempt, the engine sputtered just a bit, then every single time thereafter, absolutely nothing. It cranks incessantly but doesnt catch even a little.
Having had a past fuel pump failure give me similar symptoms, I checked this out and the fuel pump is fine. Pulled the plugs and made sure I'm getting good spark...all OK. I site down each of the cylinders and can at least confirm that all pistons are moving up and down.
Thinking maybe I broke the timing chain, I pulled the valve cover. Timing chains look fine. Thinking maybe the timing chain jumped, I checked the timing itself and it looks good too, at least from everything I can tell by studying my Chilton manual. I'm not 100% sure about this, but here's how it looked: I turn over the engine clockwise until the #1 piston is at TDC, at which point the intake and exhaust valves are more or less facing towards each other, and the arrows on the cam shaft sprockets are facing up, and the rear end of the cam shafts where the square end flats are parallel with the valve cover, and the 2 dimples are up. Does this sound right?
So I'm now thinking that I have not slipped the timing, so I do a compression test on the cylinders and find that I've got ZERO compression in all cylinders!!! How can this be? Did I bend all the Valve rods? Is something the matter with the lifters?
Surely I can't have a cylinder or piston ring issue that manifested itself instantly! If that was the case, the engine would have been running like crap, burning oil, etc. for weeks leading up to the failure, and this was not the case. It was running fine right up until it dying.
So that's my dilema. Any ideas about what's wrong and what to do about it? I'd love to hear from anyone with any suggestions>
Hnilsen@canalbarge.com
Post by: a930rocket on March 12, 2011, 06:26:25 PM
A compression test only does so much.
Although the valves are moving, they may be bent. Do a leakdown and see where the air is coming from. Intake = bent intake valves. Exhaust = bent exhaust valves. Crankcase = broken/etc. rings
Quote from: hnilsen;102198
Post by: a930rocket on March 12, 2011, 06:29:00 PM
Now my car...
142k miles. 2nd owner, so I don't know what was done prior to me owning it. Engine sounds good though.
I'll probably do a a timing chain, gears, etc. sooner than later.
Title: How do I perform a leakdown test?
Post by: hnilsen on March 18, 2011, 09:01:22 AM
How do I perform a leakdown test? I'm guessing for the intake side, when cranking over the engine I need to make sure that the engine is sucking in air? But how much air? Do I need a vacuum gauge and if so, what should the readings be?
I'm also guessing for the exhaust side, I need to be sure that the engine is pushing out air. How do you recommend this be done? My half-assed guess would be to put a plastic bag over the exhaust and crank over the engine to see if it fills. Is this too amatuerish?
Appreciate anyone's help on this.
Post by: DesktopDave on March 18, 2011, 09:37:03 AM
Leak down tests use an air compressor.   It's connected to a bung that you screw into the spark plug hole, with a two gauges to measure PSI.
Compression tests use a pressure gauge on each plug in turn.  You thread them into the spark plug hole & turn the engine over, then guess what the little bouncing needle is trying to tell you.
You're talking about a vacuum gauge, different beast there.  A vac gauge is a great way to determine fuel economy & general engine health.  But you should test each cylinder individually to get a really good idea of what's right & wrong with the motor.
I'm not usually going to give advice like this, but I'd strongly recommend getting a good mechanic to do the tests.  It's a bit more expensive, but having an experienced mech do it right will save a ton of frustration.  For instance, if you decide to use cheap HF gauges and spend hours of frustration trying to guess what the compression gauge reading actually means (not that I know about that firsthand).
So for a leakdown test, you'd have to pull the plugs then test each cylinder in turn (four tests for the mighty M42):
1. Turn motor over to TDC on the power stroke for the cylinder you're testing (both valves closed)
2. Lock the motor (you don't want to turn the motor over with 100psi pressure)
3. Pressurize the tester, say to 100psi on the compressor regulator
4. Measure how much pressure you have at the plug.
5. Divide the cylinder psi with the compressor psi and you'll have a percentage that each cylinder will hold.  It's not a perfect test but a good diagnostic.
Here's a better description with some pics: http://www.meyerracingonline.com/leak.html
Post by: pdxmotorhead on March 18, 2011, 11:36:58 AM
+1 Leakdown test is next. .... Should tell the tale. Measure the installed valve spring height, if you have bent ones the height should vary a bit.. Be out of spec at least.
Dave
Title: e36 all the way
Post by: Home made iS on March 22, 2011, 04:33:24 PM
Quote from: DesktopDave;102159
Nah Dave Ive put the whole engine loom etc onto the standard gearbox, with original m40 mounts, and moved stuff round a bit lol, exhaust had to be modified to fit as RHD e36 are much wider that e30s and the steering shaft didnt fit :confused: (I'm in Australia) other thatn that its an e36 in an e30 body :)
Post by: Toby B on April 15, 2011, 12:32:42 AM
well, since the thread's back-
pulled head at 179k due to a failed black plastic water pipe,
and the majority of the chain components are fine.
The vertical rail on the tension side, however, had lost adhesion to the metal-
how much longer it would have gone is anyone's guess.
And all the solid plastic tensioners were very brittle.
So my take is that they probably would have come apart pretty soon...
I'm replacing all the plastic, and leaving all the metal (except the tensioner)
because, well, the car was $600...
fwiw,
t
Post by: Balkanac on May 01, 2011, 11:08:06 PM
can someone post a photo of good and bad cam gears please?
I took my cover off a month ago but im not sure what good teeth are supposed to look like
Post by: bmwman91 on May 02, 2011, 12:40:52 AM
My oil pump sucked a chunk of timing chain around 150k. I bought it w/ 140k miles on it & the PO had really let the timing assembly go. Pieces of chain roller broke off & fell into the oil pan.
A couple of upper oil pan bolts had also fallen out, and that could have lead to an oiling system failure if I hadn't put them back w/ some Loc-Tite.
Post by: Balkanac on September 20, 2011, 12:42:14 AM
So noone has a photo of bad gears??
Post by: -318is- on September 20, 2011, 07:27:06 AM
Quote from: Balkanac;106790
google is your friend
(http://t1.gstatic.com/images?q=tbn:ANd9GcQau5U_JYXsI9X2dV_Sg4R6aUTd06CqgaM1oHFxo_p6_EapRKDA)
Post by: flyinglizard on February 22, 2013, 08:42:16 PM
If you bent the valves the lifters wil be loose as the valves dont come allof the way up. Either way you will need to pull the head.
The rings and bottom end  last a long time( 500k)  with synthetic oil. Not so much with crap oil.
