DISCUSSION => Engine + Driveline => Topic started by: E30nate on April 13, 2008, 01:21:23 PM
Title: Engine dead?
Post by: E30nate on April 13, 2008, 01:21:23 PM
so yesterday my car started running like crap, and now it is blowing blue smoke out the tailpipe, which leads me to believe bad rings. so i did a compression test today, and it didnt look too good, but it didnt look horrible either.
when i first bought the car, it had 210psi across all cylinders, today it was as follows:
cyl 1: 175psi
cyl 2: 200psi
cyl 3: 175psi
cyl 4: 200psi
so is this bad, or could it be something else. i dont have the tools to do a leakdown test, but if i have to i can run and get them from harbor freight.
thanks in advance.
Nate
Title: Engine dead?
Post by: Wise Old Dog on April 13, 2008, 03:48:23 PM
For whatever reason either valves or rings are leaking. Squirt some oil in there and check it again to eliminate ring leak.
175psi isn't terrible, but you have a high percentage difference from the adjacent cylinder,ie more than 5%.
You're going to have to fix something, you just need to find out what.
Title: Engine dead?
Post by: E30nate on April 13, 2008, 07:28:39 PM
i took the head off, and found pieces of bearing on the TOP of the cylinder:eek:. so needless to say i need a new engine.
Title: Engine dead?
Post by: bmwpower on April 13, 2008, 08:49:31 PM
Quote from: E30nate;46952
pieces of bearing?  WTF?
What do you think it's from?
Title: Engine dead?
Post by: E30nate on April 13, 2008, 10:12:59 PM
thats exactly what i thought. WTF? the only thing i could think of is maybe the piston skirt broke and let it by on the downstroke. after i get a new engine i will take this one apart and check it out.
Title: Engine dead?
Post by: kowalski on April 13, 2008, 10:19:04 PM
pics or ban.
