DISCUSSION => Electrical => Topic started by: jakeb on March 29, 2008, 06:44:45 AM
Does anyone know how the tach signal works? I have a m42 in my 2002 and trying to get the stock 2002 tach to work. I connected it to the signal off the c101 plug but not getting anything. So trying to figure out how I can get it to work or if I should go with an after market gauge.
I was able to really drive the car yesterday and it is fun fun fun. The sound when you stomp on it is pretty insane. I am running two straight trough magnaflows. I will have to take a short video of it.
Jake,
Ive got an e21 with an m42 swapped in and Ive run into similar problems.
Heres a post string I started some time ago that should shed some light on the situation.
http://forums.bimmerforums.com/forum/showthread.php?t=946870&highlight=pinouts
Hope it helps!
Also, if you want to spend a little money ($80 or so), this seems like the easiest and least finicky solution.
http://www.msdignition.com/ignition_27_a_8913.htm
Reviving a old thread sorry..
I am wiring in an aftermarket engine management system which outputs a 12v pulse for RPM. Will this work with a E36 guage cluster or does it require a 5v signal?
What have others done for RPM signals to standard guages when using a aftermarket system?
Any info on what the guage cluste expects as a signal much appreciated..
It might be that the tach gets an AC signal...and the MSD linky above is down. Here's a link for you (not sure how helpful it'll be): http://m3forum.net/m3forum/showthread.php?t=322373
If the car is still running, test that OBDII port pin 9 & see what it pulses at, AC or DC.
CheersDave,
I should have done that before i yoinked out the the loom and ecu. Hindsight is a wonderful thing.
I know of others running my ecu in e30's and they connected it right up but i just want to tripple check before blowing somthing up. I have the option to adjust duty cycle etc on the ecu so may start concervative and work up..
I'm pretty sure it's not a very powerful signal...I'd be willing to bet that 12vac and 5vac will both work. YMMV The caps in the cluster are cheap but not so much fun to replace.
