DISCUSSION => Electrical => Topic started by: martin347 on March 23, 2008, 06:21:16 AM
Title: m42/m44 crank sensor
Post by: martin347 on March 23, 2008, 06:21:16 AM
Does anyone know if the m42 and the m44 crank sensors are the same?
I know they are in different places, but is the actual sensor the same?
Thanks, Martin.
Post by: hoevesruperd on March 24, 2008, 01:23:22 PM
sorry i cant help but would like to bump this and ask:
is there a way to test the cam sensor?
Post by: D. Clay on March 24, 2008, 03:58:22 PM
The sensors are the same type and the M44 block mounted unit is compatible with the M42 electronics. The cam sensor is different.
http://m42club.com/forums/showthread.php?t=4645
Post by: RED IS 91 on March 24, 2008, 05:36:23 PM
Quote from: hoevesruperd;45362
Hook an ohm meter up to the two pins at the plug end . You should have about 1260 ohms .
Post by: hoevesruperd on March 25, 2008, 07:49:51 PM
thanks! i'm still wondering if this is the problem (i cant test it right now)
i have misfires issues and was wondering if it could be the cam sensor or crank sensor?? i will do a complete ignition COP overhaul since that could also be the problem and i always wanted to upgrade to COP
i can't find any part number for the crank sensor and the only price i have is from bavauto and its really expensive: 169$!!
thanks for the help
