DISCUSSION => Engine + Driveline => Topic started by: blysccr on March 19, 2008, 07:57:49 PM
i have a 318 i. there are no marks on the oil pan. is there any reason i should check to see if the oil pan is moved? can i look at it from underneath? if there are no markings, what are the chances that something is messed up? what vacuum line do i pull to seafoam it? thanks
what are you checking the oil pan for? the loose bolts? Thats on the upper pan, you need to take off the lower pan to see them.
