DISCUSSION => Engine + Driveline => Topic started by: BrandC on February 05, 2008, 06:38:08 PM
Hey guys,
I'm in the middle of doing my M20 flywheel conversion, can you guys tell me which clutch alignment tool to use? M20 or M42? Thanks!
Brandon
M42. But remember, there are 2 different sizes of the Getrag 240 input shaft. The early version has a smaller size shaft, which makes the pilot bearing inside diameter smaller. The later model is larger. Check the realOEM website for the pilot bearing part number. It will state when the size was changed.
