DISCUSSION => Engine + Driveline => Topic started by: Demelich on December 05, 2007, 08:14:58 PM
Title: Whine from the rear
Post by: Demelich on December 05, 2007, 08:14:58 PM
I recently purchased a 91 318is.  I have found other threads with similar problems, but I would like to get some other opinions too.
The problem is that over about 25MPH, I hear a whine coming from the back of the car.  It is kind of like the whine from a DC fan spinning at high speeds.  The whine increases in pitch, but not so much in volume as speed increases.  The whine seems to be directly related to wheel speed.  If I push in the clutch and shift to neutral while going 65+, the whine stays the same and slightly decreases as speed bleeds off.  Braking makes the whine reduce in pitch and volume much quicker than if I just coast.
The previous owner said that the problem started after he installed a new fuel pump, and the sound itself really does seem like it could be the fuel pump.
The problem is that the symptoms do not seem to be consistant with a fuel pump (in my opinion  anyway, Ive never had a fuel pump issue before) because even if I have the engine idling in neutral at highway speeds, the whine remains the same.   Could it be that it just takes a while for the fuel pump to reduce its speed?
I do not believe that the problem is wheel bearings either because even hard turning does not effect the whine in anyway.
I think that it may be the guibo, or something driveshaft related.  Otherwise it may be the differential itself although the diff seems to be working fine.
So, could I just be wrong and I actually have some sort of leak in the fuel system or a bad fuel pump?  Or does this sound like a driveshaft/differential issue.
One last note, the whine remains steady no matter what gear I am in.
Post by: hoevesruperd on December 05, 2007, 08:23:33 PM
i had a similar problem, thought it was the wheel bearing but then i realized that my front wheel was really hot. my caliper was clogged and the pads where lightly grinding on the disk. before you start to worry too much, check if your wheels are excessively warm after driving.
i'm in no way assuming this is your problem, it could be anything wheel related. if you say that the sound keeps on going and keeps its pitch when the car is in neutral while rolling i doubt it would come from the differential or the shaft as these go with the rpm
Post by: Febi Guibo on December 06, 2007, 03:35:35 AM
my money is on the diff (output bearing going bad)
Post by: RED IS 91 on December 06, 2007, 07:53:07 AM
Quote from: Febi Guibo;39007
+1 ^
Post by: Demelich on December 06, 2007, 07:56:26 AM
I have been thinking diff also Febi Guibo.  I assume the diff needs to be dropped for pretty much any maintenance.  Is the output bearing something that can be done, or is it cheaper and easier to buy a new rear end?  It seems to me that in most cases it is.
On the other hand, the previous owner also put on new pads and rotors.  The brakes squeek a bit, so its possible he botched that job.  I will check that out, but the noise is definately coming from the back, not the front.
Post by: hoevesruperd on December 06, 2007, 09:12:55 AM
Quote from: hoevesruperd;38978
just realized i'm totally wrong here
Post by: nicknikolovski on December 07, 2007, 04:00:05 AM
I got a 93 318is coupe and I just started noticing that same noise but only from the right hand rear side. Let me know what your outcome may be?
Post by: DZick on December 07, 2007, 10:07:02 AM
If it is a whine all the time (even when not moving) probably fuel pump going bad. they usually get loud when they are about to go out.
Other wise if it does it only when you move id bet on the diff.
Post by: hoevesruperd on December 07, 2007, 11:47:35 AM
Quote from: DZick;39075
remove your back seat you ll be able to tell in 2 seconds if its your fuel pump. but fuel pumps are more of a buzz sound than a whine.
Post by: Demelich on December 07, 2007, 12:39:22 PM
Its a fresh fuel pump on mine, of course its possible the previous owner screwed up when installing it somehow.
I am about 90% sure its the diff, but Ive had both the previous owner and my dad try to tell me its the fuel pump.
I am just about to call a shop to check out the diff, so I will see what they have to say.
EDIT: Just a quick update, I have not had a chance to contact the shop yet.  I only work till noon today though, so I am going to head over today.
Post by: Asserti on December 10, 2007, 09:59:08 AM
Got the same problem. But I located the sound to come from right under my passenger ash tray. I used pieces for the cardan from two different cars. I think the connection between the two pieces makes the sound.
Post by: cheesebox on December 11, 2007, 05:18:40 AM
It's also possible part of the hand brake assembly has come adrift in one of the rear drums.
To verify, drive until you hear the sound, then gradually pull on the hand brake. If the sound disappears then that is your problem.
Post by: sheepdog on December 11, 2007, 08:47:35 PM
Does it change based on acceleration vs deceleration? That would be gear whine.
If it changes only based on speed it is a bearing.
Could be diff or wheel, have a buddy sit in back he may be able to tell which.
Post by: Demelich on April 25, 2008, 07:46:38 AM
So an update (finally).
I have done a bit with my car since then.  A bunch of new suspension parts, control arms, springs, shocks etc.  Anyway, more importantly, I have replaced both rear wheel bearings, and put in a 4.10 LSD from diffsonline.com.  One of my rear calipers locked up as well, so my rear calipers, pads and rotors were replaced.
The whine is still there.  It really sounds like it is coming from the back, but I wonder if my driveshaft is making the noise.  My ebrake seems to work properly, so I do not know if that could be it.
Before replacing the diff, I lifted the rear wheels up and spun them up to about 60MPH.  My mechanic friend said that the noise was coming from the diff.  Since I have a new (used) diff and the noise is still there, I am looking towards something with the driveshaft.
I think my next step is to check out the Guibo/flex disk and center bearing.
I wonder, could it simply be my tires making noise?  Sounds more mechanical/metal than a rubber on pavement sound though.
Post by: r0ckrat on April 28, 2008, 04:53:59 PM
Sounds like a possible center support bearing on the driveline - back under the rear seat, but not as far back as the diff.
Post by: a.12912 on April 29, 2008, 12:37:50 AM
Hi,  a member for some time now and have only posted for help; now time to give back a little.
Having said what has been suggested and having had similar problems.
The remedy was: new non directional tyres.
The reason being as that directional tyres are noisy by nature in general and when tyres succumb to uneven ware such as on a lowered BMW with independent rear end. The tyres were worn to the wear indicators on the inside and on the outside was 3mm away. At approximately 60mph 100kmh the noise (wining / metallic drown) became unbearable.
Thoughts were wheel bearings, drive shafts, diff, centre bearing and or flex joint. Though having had a full vehicle inspection none of the above mentioned was a problem.
The remedies where; rotation of tyres (front to back),. alternatively replace with new non directional quality tyres (Toyo TEO Plus) as tested successfully.
Hope this information may help.
Post by: sheepdog on April 29, 2008, 12:15:52 PM
Thanks a.12912, I have never heard of this.
I am experiencing this right now and have been getting ready to do the bearings.
I have the same symptoms, inner and outer wear and directional tires. I am going to try swapping them around and see what happens or use my spares.
Would be nice if I did not have to do the bearings.
Thanks!
Post by: sheepdog on April 29, 2008, 02:49:41 PM
Well it calmed my whine down some, but not completely. Not sure if it is the tires or the bearings at this point.
Post by: Demelich on May 09, 2008, 10:30:48 AM
Another update.....
I replaced my diff.  The noise is still here.  I am going to replace my center support bearing once I get myself a new air compressor.
The only driveshaft I have messed with is with my 300ZX, it just has a rubber center support.  I did not realize that the BMW center support has an actual bearing that connects the two driveshaft pieces.  This has got to be it, it sounds exactly like a bad bearing.
Post by: peerless on May 09, 2008, 12:25:20 PM
I have done about 6 driveshafts on the E30's now. Typically the CSB is broken before the bearing goes out. But this is all on 6 cylinder cars where you have more torque. The M42 maybe easier on the driveshafts.
If your going to replace CSB, make sure of course to get the front flex disk. (I honestly don't know where the term 'guibo' ever came from.)
Be aware though every driveshaft I have pulled needed to be rebuilt. I have done 3 without rebuilding and every one has taken a crap within 6 months to a year. That was on 2 E30's and a 93' 540. They all ended up coming back for a driveshaft rebuild and ended up paying twice.
Another tip when removing the driveshaft, it is extremely important to keep the 2 drveshaft halves correctly aligned. Mark both halves clearly before separating the 2 halves. If not you WILL have a bad vibration and a huge headache trying to fix it.
Also guys (and gals) I specialize in E30 repair and service and run my own home based shop full time. I am new here so I didn't want to jump right in with advertising my shop. I do everything from driveshafts, suspension, dash replacements, engine rebuilding (currently building a M30, 2.9 M20, and 2 M42's), and anything else on a E30. Only things I don't do are paint and body.
Post by: sheepdog on May 09, 2008, 08:01:25 PM
Quote from: peerless;48994
Wish you lived closer to me, I would have you do my wheel bearings.
Post by: ScreamerBeemer on May 09, 2008, 09:54:03 PM
Ditto
Post by: el_gringo on May 10, 2008, 09:56:42 PM
Sounds like your trunk hinges are loose... or maybe the blinker fluid pump is going out. While your at it, update your fluxcapacitor...
Oh yeah, don't forget to lube the tampon dispenser. ;-)
Post by: el_gringo on May 10, 2008, 10:05:09 PM
Ok now to be serious: your diff is fucked. When its locked it wil usually whine like a screaming cat. Trust me, my old eta did this from beating on it. (My eta would eat a m42).
Check the fluid.
Then drain it and fill it properly with the CORRECT fluid and possibly additive.
Then drive.
If it keeps whining, come back.
Yes, when you put the transmission in neutral, the diff will keep spinning, dumbass.
Shoot me a pm if you have anymore questions.
