DISCUSSION => General Topics => Topic started by: stever318is on November 21, 2007, 02:33:07 PM
Title: lost odometer after engine/tranny pull
Post by: stever318is on November 21, 2007, 02:33:07 PM
just got the 91 back on the road pulled eng/tranny to do a upper oil pan.
Odometer is only thing not working. It is a sensor in the rear end? i checked it seems tight. Do i have a elect connector in the wrong spot? Funny thing is i've put two different connectors into mass air flow sensor with no change in driveability they are exactly the same type i had forgotten which. Any pics or suggestions where to check
steve 91 318is
Post by: nickmpower on November 21, 2007, 06:34:38 PM
if your speedo is working and odo isnt then its the odo gears in the cluster
Post by: stever318is on November 22, 2007, 01:55:34 PM
Yes the speedo works, the odometer did before i pulled engine. So without a doubt my gears went bad by chance.
thanks
