DISCUSSION => General Topics => Topic started by: nev parker on November 06, 2007, 11:13:04 AM
Title: air bag wheel removal
Post by: nev parker on November 06, 2007, 11:13:04 AM
Ok Guys, i'm a new member.
I need to get the air bag steering wheel off,i'm sure its not difficult, just haven't done it before........
pls let me know
Post by: ak96ss on November 06, 2007, 12:18:39 PM
Disconnect the battery. On the bottom of the steering column is a little 'trap door' that hides the connector for the airbag. Disconnect this. Whatever you do, don't reconnect the battery until the airbag is back in place and this connector is connected - it may set off the SRS light on the check panel, and the dealers can't even reset this anymore, to the best of my knowledge.
Two torx-bit screws on the back of the wheel hold on the airbag. Once those are loose, you can pull the airbag off of the wheel. Set it someplace safe - remember, it is an explosive device.
Mark the orientation of the steering wheel to the column stud with an awl or a marker.
Now, get a big wrench and 22mm socket (or is it 21mm?) and pull the nut off.  BMW calls for replacing that nut with a new one, but I just use blue Loctite when reinstalling.
When removing and reinstalling the wheel, you need to make sure that the turn signal is in the center/neutral position. Otherwise, you could break off the plastic pawl that cancels the turn signals when you turn a corner.
Put your key in the ignition, turn it far enough to disengage the steering wheel lock, and remove the wheel.
Installation is the reverse of removal.
Post by: 1988E30M3 on November 06, 2007, 02:02:43 PM
I just did this last weekend.
The torx wrench is a T-25 and the nut holding the steering wheel is 22mm.
Enjoy!
Post by: ducatipaso on November 06, 2007, 04:15:19 PM
ditching the gigantic 4-spoke wheel and switching to an mtech1 was one of the most satisfying mods I did to my E30 :)
Title: airbag wheel removal
Post by: nev parker on November 14, 2007, 08:12:33 PM
thanks for the replies on airbag wheel removal............
Post by: dyno4mance on December 15, 2007, 07:41:44 AM
Quote from: 1988E30M3;37262
Enjoy!
The torx is a T-30
