DISCUSSION => Suspension => Topic started by: FloridaE30M42 on October 29, 2007, 04:08:02 PM
Title: Suspension diagram
Post by: FloridaE30M42 on October 29, 2007, 04:08:02 PM
Anyone know where i can find a diagram or cross section of the whole front suspension?
Post by: EN318isPDX on October 29, 2007, 04:26:34 PM
Quote from: FloridaE30M42;36818
Its in the Bentley for E30. If no one else posts it ill get it scanned when i get home from work
Post by: FloridaE30M42 on October 29, 2007, 06:27:08 PM
Thanks I appreciate it
Post by: Spec 2 on October 30, 2007, 03:30:02 PM
This Bentley manual sounds like a good thing to have...
I'd also like to see the diagram if you can post it.  Thanks!
Post by: Bunta on October 31, 2007, 07:24:58 PM
Front
 (http://www.imagehosting.com/out.php/i1320436_frntsusp.jpg) (http://www.imagehosting.com)
Rear
 (http://www.imagehosting.com/out.php/i1320445_rearsusp.jpg) (http://www.imagehosting.com)
Post by: EN318isPDX on November 01, 2007, 10:25:14 AM
Thank's Bunt It seems that my scanner is broken! Hope it can still print
Post by: FloridaE30M42 on November 05, 2007, 09:25:14 PM
Is this Setup the same as other E30s including 325's?
Post by: sumyungguy on November 06, 2007, 12:05:39 AM
Are you wanting to use those for what I think you are?
Post by: KenC on November 06, 2007, 12:11:44 AM
Quote from: FloridaE30M42;37235
M3 front sway bar linkage is different.
Post by: FloridaE30M42 on November 06, 2007, 01:20:03 PM
Quote from: sumyungguy;37239
What exactly do you think i will be using them for?
