DISCUSSION => General Topics => Topic started by: twinpop171 on October 09, 2007, 09:13:10 PM
Well just as the title says I did the DIY last Saturday afternoon. The job was really not as difficult as I thought it may be. I'm lucky because I have access to a lift and it made the job WAY easier. The hardest part of the job was removing the outer tie rods from the old rack. In hind sight I probably should have replaced them but they were still nice and tight.
It is so nice not to have the embarassing trail of ATF following my car with the subsequent puddle under it.
BIG thanks to Sheepdog for recommending http://www.discountsteering.com
$215 with free shipping for a remanufactured ZF long rack with a 36 month warranty.
If anyone is apprehensive about changing one, don't be. It really wasn't that hard but an extra set of hands is kind of necessary at times.
Dan.
Dude! You should have spent that money on a used e36 rack...preferably from a 96-99 car...
The difference between the e36 rack and the e30 rack is literally NIGHT and DAY!
Either way, a steering rack in good shape is better than one that is constantly leaking!
Dan.
Good job.
Hard to beat their price.
Too bad the 1995 M3 rack is listed as the same as other E36's...I'd imagine they'd give me a non-3.0 turn-to-turn rack.
Good job.
Manual steering? I don't see the point of PS on this car unless you're using hugely wide tires.
In some states, like mine, if it has power steering it must be hooked up and full of fluid to pass a safety check or you cannot drive.
To remove the power steering you have to remove all traces of it. I was fine without it, state said I had to hook it all back up.
Still $200 to fix it is not bad.
I considered an e36 rack after reading your FS post last month. I know that minimal mods can make it work but I was unsure of what they were. If I ever decide to track the m42 then maybe I'll look into the e36 M3 rack. It does sound intriguing though.
Dan.
That sounds like a stupid law. In California its emissions only. The smog nazis couldn't care less if your car is totally unsafe to drive. No inspection whatsoever.
Dan.
Actually, mine fit without any modification whatsoever.
I would most certainly consider it for track use and daily use...you'll be kicking yourself in the head later!
Either I didn't get an e36 rack until I dropped $400 on a stocker which died anyway :rolleyes:
Not as stupid as you think.
California does not get snow fall across the state. Plus they have enough problems with crap cars on the roads here, and some of the worst drivers in the country.New Year and St. Patrick's day in St. Louis is like driving in a 3rd world country.
Stupid as it is, I would much rather do this than go back to dealing with California emissions again, I can drop any engine in that I want. I drove mostly pre-smog cars while I lived in Cali.
The end seals on one side of my rack blew out recently, and I have been driving without the PS belt (just rebuilt the damn pump, too). I really want to look into the E36 M3 rack. You say that NO modifications are needed?
I thought you had to bend some tabs 90 degrees and replace part of the steering shaft / bushing / something? I no longer have any airbag nonsense on the car, so whatever I heard about not being able to use it with the E36 M3 rack does not matter there.
Are you running with PS currently, and if so does it all hook up easily to the stock M42 pump? Any pics of your install? Thanks!
There are mods needed. The tabs that need to be bent are the two black ones that bolt to the bottom of the existing rack. They need to be bent so that you can get the old one out and the new one in. The lower link also has to be replaced with a lengthened one, and Zionsville autosport among others have these. Also, you will need a new high-pressure hose with the correnct fittings and angles, although I have heard that it isn't difficult to modify the existing one. Having the airbag doesn't matter; airbag cars had differently-angled steering shafts and firewall holes, so I think it takes a bit of work. This is one of the reasons I haven't done this yet.
BTW what makes the 1995 m3 rack so special? Is it different than other e36 m3 racks?
I'll get some pics for you once its stops raining!
The tabs that hold the rack have to be bent in order for you to remove it. Spacers need to fitted so that the E36 can go in there with no play.
http://www.r3vlimited.com/board/showthread.php?t=66247&highlight=DIY+e36+steering+rack
You'll find every answer there.
No high pressure lines need to added, all of that is nonsense.
You must bend the lines leading to the rack and thats pretty much it.
I'll try to get some pics of my setup.
Hmm, it says something about having to modify the firewall on ABS cars...I might have to pass on this.
http://www.rmeuropean.com/bmw-steering-rack.html
Bottom half of the page.
so the E36 steering rack is quicker? That's cool. The steering on my car is a bit light, and not always to my taste.
I've got power steering. Not as communicative, but I guess the ratio is a bit quicker than E30's w/out power assist. I'll have to look into deleting the power steering (and the AC while I'm at it..)
Like I said, nonsense.
You can go do without most of the stuff he mentions.
I simply swapped my old rack out with this one.
You will need E36 inner and outer tie rods though...they're beefier as well :)
That is a really nice write-up!
Ouch!
All of this confusion about doing the e36 rack install is what steered me back to the stocker. I could never find matching write-ups. I don't have any e30 enthusiasts locally to compare mods/ideas with and to physically check out mods with.
At least one e30 is dry underneath now. Time to replace all the seals in the m20 beater now. My driveway was recently sealed and Mrs. m42 isn't liking the leaking e30s too much:rolleyes::p
OK, I guess I will take the plunge and do it. My parts list on BMA is the following. Is it all correct?
Maval Rebuilt rack for 1995 M3
Left Tie Rod Ends + Ball Joints for 1995 M3
Right Tie Rod Ends + Ball Joints for 1995 M3
2 x Boots for 1995 M3
2 x Lock Plates for 1995 M3
2 x Clamps for 1995 M3
From Pelican I will be getting:
New PS fluid resivoir
New pump belt
Forget the new high-pressure line. Mine doe snto seem to be leakign, and for some reason the M42's costs $240, while the other E30 ones are like $60. As for the other low pressure lines, I will just get some generic hose from the local parts store and clamp the hose ends into them.
Am I missing anything?
Nope. Your list of parts looks complete :)
Where are you purchasing the rack from?
Take look into those spacers btw...
72-11-1-847-480
I would throw that in the order as well!
New pump belt
Sorry for the confusion with the info I posted. All of the writeups on this that I have ever seen required firewall mods. I know that the original high pressure line can be used, but I thought that the fittings were the wrong size...An interesting point is that most of those writeups were on bf.c ... ;). Turns out they also dealt with an airbag e30 M3, so that might be part of it too.
hope I didn't cause any undue problems...
Jordan
72-11-1-847-480
I would guess that I need 2? Do they go between the subframe and rack?
And yay for having an engine hoist. I can probably avoid bending the mount tabs.
Yes sir!
Engine hoist... One of my next purchases.
I lucked out on mine...garage sale from what looked like a divorce settlement. $25 for a brand new one with a 1.5 ton capacity. It was a real find lol. Too bad she wasnt selling his M3.....
I got a hubbys laptop in a similar way.
Free, well it cost me 10 minutes of work on her computer. 2 year old refurb'ed Sony laptop ($3000 when new).
Also scored my Miata that way $500. It had to go.
A buddy scored a NICE 64' Cuda for $12k that way as well.
Maybe it is just because I watched Nash Bridges as a kid or something, but I would KILL for a 'Cuda. Those things are sick as hell!
SHIT, BMA won't give me my core charge back from the E36 rack in exchange for my original one. Any tips? I really don''t want to miss out on $150 AND have a piece of shit rack leaking all over my garage.
A lot of places will not give you a core for the wrong rack.
Try the place linked in the start of this, they are so much cheaper you may not miss out on the money without ever sending one back.
Well, I wound up going to http://www.car-part.com and getting a 1997 Z3 1.9L rack (2.7 ratio) for $220 shipped. It has 105k miles on it, and the guy assured me it was leakless. Apparently they usually don't sell the racks, but rather send them out for rebuilding & then sell them. He He said they only sell one if it has no leaks whatsoever. For $220, who cares.
Stuck (Jordan) said that rebuilding them is a real PITA, and damn near impossible. Anyone tried it before? Now I have one to practice on lol.
Is it possible to sell my rebuildable core to some rebuilder for a core-price? It would seem like rebuilders would be receptive to this since they still make $ off of it.
