DISCUSSION => Electrical => Topic started by: Meister on September 12, 2007, 07:30:21 AM
My 91 318iS didn't come with fog lights, i just have the covers where they go but no fog light switch inside. So my question is, how to i know if I am already prewired for fogs and how hard would it be to install? or if I am not prewired how would i go about getting some on?
They pretty much all came prewired - I hesitate to say they all definitely did, because as soon as I do someone will produce one that didn't.
However, I've never seen one that wasn't. Look behind the blanks where the foglights are. It may be tucked way up there, or taped to the harness, but you should have a connector hanging up there with two wires going into it. If you have one on each side, and you should, you are prewired and only need to install the switch and the fuses and you are good to go.
My connections were down below the headlights behind the covers.
Ok thanks i'll check it out
The other end of the wires is often above the orange airbag control module behind the instrument cluster. Sometimes they fall down behind the box (like mine) and they are a pain to get out. You really need to take out the cluster to do this.
It should be pre-wired but you will also need the fog light switch, fuse and relays.
I was lucky, mine had the relay, the fuse, the switch, and the wires righ next to the covers... and I have a 318I. Sorry, just rubbing it in :p
I still haven't had much time to look into this yet but, if I were to be able to hook all this up, could I do it with out having to hook up the switch inside?
How would you turn them on and off?
What I mean is that if I hook them up without using a switch, would they turn on with my headlights?
Not unless you rewire them. You would have to have a separate relay to turn on the fogs, as I don't know that the existing wiring for the headlights is heavy enough to run both the headlights and the foglights.
I wouldn't run them both on it, anyway.
Pretty easy though, just use a relay triggered off the low beam light to turn on the fogs.
