DISCUSSION => General Topics => Topic started by: P. Kennedy on September 07, 2007, 11:54:16 AM
Any good guesses as to the quantity of petrol remaining when the low fuel light comes on? I was thinking I would easily get 325 miles per tankfull, but yesterday I ran out of gas at 326. As luck would have it, I was able to coast downhill into a Mobil station (& they have 93 octane to boot.)
I always reset my trip odometer when filling up with gasoline, but I've only had this car a few weeks, so I won't cut it that close any more.
For those that track mileage with trip odo., how far do you go on a tankfull?
i fill up at 1/2 tank or 1/4 tank.....i never go below a 1/4.......not after spending $150 for a fuel pump, i want it to last.
But to answer your question: we have a 14.5 gallon fuel tank and i am 80% sure the light comes on when you have about 2 gallons left. (roughly 50 miles once the light comes on). I have driven way further than 325 miles on one tank though, you should be getting at least 350 untill your light comes on......freeway driving.
one time I was on the highway in the middle of nowhere when my light came on. I drove another 40 miles before I filled up ;)
I can get 12.8 gallons into my tank when the light comes on. I guess the reverse of that is 1.7 gallons left.
^^^ +1 ^^^
It takes ~12.5 when my light comes on. The furthest i've ever gone on that was a little over 400 miles. I put in 13 gallons once but the engine felt like it was starting to lose power in turns so I guess the fuel pump has trouble pumping out the last gallon or so. I wish I had the 16 gallon 6cyl tank.
As to highway mileage, my control arm bushings are shot to hell, so I avoid the highway completely for now, hence my stinky mpg.
^^^ +1 ^^^
they have 14.5 like us to......the E30 M3 had 15.3.
The light is triggered when 1.5 gallons remain in the tank, per BMW specs.
88 325 and 325i had 16.4 gallon tank. It was a 1 year deal. M3 has 14.5
http://www.strictlyeta.net/technical/specifications2.html
good info
thanks
Huh, I could have sworn that I read in the manual that we have 12.7 gallon tanks. My low-fuel light doesn't work, even with the needle in the red, so I don't know if it is burned out or if the gauge is off. How do you replace the bulb? (I know how to get the cluster off)
BTW I only get about 280 miles on a tank, with almost all city driving and a heavy foot when getting on the highway ;)
