DISCUSSION => Swaps, Turbos, Buildups => Topic started by: steve321 on August 28, 2007, 07:04:05 AM
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=280134139325&ssPageName=STRK:MEWA:IT&ih=018
they seem very cheap for all 4 with arp bolts. i realise standard rods bolts must be uprated when making a higher reving engine, but are aftermarket conrods worth doing too, when will standard rods usualy fail, cos i'd like 8000-9000rpm really.
steve
________
Montana Dispensary (http://montana.dispensaries.org/)
You're also going to need lighter valvetrain parts to even get the engine past 7500rpm.
i will be, and a mega mega light flywheel, and lightened crank, and light pistons ect
steve
________
Iolite portable vaporizer (http://iolitevaporizer.net/)
the ad on ebay says they are for turbo'ed motors....i wonder if they have oil channels that spray oil to the under side of the piston for better cooling with a turbo.
Theres a hole in the end of the rod anyway which could be an oil jet?
except thats 400 british pounds, which is like 800$ so you may as well just buy from a known manufacture.
