DISCUSSION => Engine + Driveline => Topic started by: bmwman91 on July 16, 2007, 09:52:14 PM
I went in for the test today. I had the MAF on there as well as my Conforti chip and LC-1 WBO2. Damn close to passing, kinda. I had tweaked the LC-1 a little bit lean for economy too.
15MPH Test - FAILED (Gross Polluter to boot!)
% CO2 - 14.7
% O2 - 0.5
Hydrocarbons (PPM)
Allowable - 124
Measured - 12
CO %
Allowable - 0.78
Measured - 0.01
NOx (PPM)
Allowable - 815
Measured - 2317 :eek:
25MPH Test - PASSED
% CO2 - 15.0
% O2 - 0.1
Hydrocarbons (PPM)
Allowable - 98
Measured - 4
CO %
Allowable - 0.66
Measured - 0.00
NOx (PPM)
Allowable - 754
Measured - 714 :cool:
Since this I have put the stock AFM back in, and have set the LC-1 back to its original (too rich IMO) set points. I get a free retest, so hopefully this will go OK. I do not want to buy a new cat if I do not have to. Running a little lean usually does this on the M42 right? High compression motors are a PITA to smog, my last one sure was. Sigh, pain in the rear.....
your nox shouldnt be that high at all. if you have a good working cat and your egr system is functioning properly everything thould be good. try richening your mixture out a little bit and you should be fine.
Yeah I can tell by the econometer on the way to work this morning that it is running richer. I put the WBO2 controller back to its original (too rich IMO) setting and the AFM back in. Retesting today, 5PM sharp!
Good luck with that. Haha I love indiana smog laws, or rather lack therof ;)
Hokay, so I passed after setting the WBO2 back to its original settings (too rich IMO) and swapping the AFM back on. Talk about a narrow pass at 15mph! I think I will replace the cat just for the environment's sake!
15MPH Test - PASSED, BARELY
Hydrocarbons (PPM)
Allowable - 124
Measured - 124
CO %
Allowable - 0.78
Measured - 0.76
NOx (PPM)
Allowable - 815
Measured - 9 - Wow, what a difference 14.2:1AFR makes versus 15.2:1AFR!
25MPH Test - PASSED, with a decent margin compared to the above!
I passed smog today with a lc-1 feeding the ecu narrowband input, with a error about the heater circuit open (i left old heater wires not connected, I should solve that with a 18W-14V brake bulb...;)).
Now I'm happy, after all wiring and ground problems the LC-1 is making a great work...:D
Hydrocarbons (PPM)
Allowable - 124
Measured - 124
CO %
Allowable - 0.78
Measured - 0.76
NOx (PPM)
Allowable - 815
yupp makes sense to me.. when the mixture is a little rich it cools down the combustion chamber and nox decreases.. since you passed you can go ahead and go back lean and save some $$$ on gas
