DISCUSSION => Swaps, Turbos, Buildups => Topic started by: Tor Arne Kaasen on July 12, 2007, 03:06:27 AM
Hi ther, nead to get oil from the engine to the turbo. can i use http://cgi.ebay.com/ebaymotors/BMW-Oil-Distribution-Block-Gauges-E36-M3-325-ODB-JTD_W0QQcmdZViewItemQQcategoryZ33676QQihZ020QQitemZ300128608757QQrdZ1
ore are ther other ways to get the oil.:confused:
I just use brass fittings that you can get at almost any hardware store and tapped off the oil pressure sensor and have not had a problem yet.
that will work , but you can also lessen Werdyio2 advise
why dont you contact with http://www.ticco.com or some of his friends in Norwey
just make sure you get an orifice in to restrict the oil flow.
Do you mean restrictor,
http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ATP-OIL-021&Category_Code=GTBB
the Garrett GT seris has a restrictor biltdt in the char.
Is`t that ok with that one?:confused:
yeah, restrictor, same thing, just as long as you dont go dumping massive amounts of oil through the turbo or starving the turbo of oil you should be set.
