DISCUSSION => General Topics => Topic started by: dlmrun2002 on July 01, 2007, 08:19:48 PM
Just pulled cluster. Gears all look good. Speedometer still working. All other gauges working. Looked for "cold solders" on circuit board with magnifying glass. Didn't see any. AND--- I rotated the gears and they all seemd to work--odometer worked, etc... Could a gear been a little stuck or are we looking at an electrical problem? Any input is greatly appreciated..
DLM :eek:
I have the same problem, actually it has happened before and just miraculously started working again. The last time it quit was about 10 minutes before a fill up, I noticed it didn't work but when I left the gas station it started working again. Who knows. It would be great if it was just a blown fuse or something , it always seems to be a blown fuse, haha.
Check the wiring at the sending unit in the differential. Mine had corroded through, and stopped working.
Bet you a donut that it's the wiring back there.
You can pick up replacement wiring from the stealer or BMA; pop the plastic cover on the connector body, remove the original, and put the new connectors in. Of course, the wires will both be green now, since the replacement wiring does not come with the proper color-coded wires, but it's not hard to do.
If my records are right, the part is Cable Socket (pigtail) 61 13 0 007 445.
Do this even if the speedometer is still working???? I just lost the odometer and tripometer..not speedometer..
DLM
Ahh - it was early in the morning, forgive me, I missed that.
OK, so how does your SI board look? I'd check that next, see if it needs new batteries.
Speedometers works.... not odometer or tripometer with a different speedometer. Bad circuit board? Possible faulty code plug? WTF..
DLM
As ak96ss said, check the rechargeable batteries, they are located inside your cluster, they need to be replaced if they are old
Si board looks good. No sign of malfunction. I know what that's like.. NO tach.. no mpg gauge.. interval and oil lights on and won't reset... I was thinking of doing a reset on si board any way. See if it helps. But it IS odd that I got the same symptons with a different speedometer...speedometer working but no odometer ( or tripometer)
Well after swapping speedometers, I exercised the si board and control plug connections and odometer is working. Never actualy had to reset si board also. Lets see how long it holds.
DLM :)
