DISCUSSION => Swaps, Turbos, Buildups => Topic started by: nuvolarossa on June 18, 2007, 07:11:00 AM
Title: Italian E36 M42, NA 197hp, 168ft-lbs, E30 S14 ITBs...
Post by: nuvolarossa on June 18, 2007, 07:11:00 AM
Hi, I want to show you a thing that made me dream since 2004, year of this article. It's from a Italian tuning magazine.
The car is a M42 318is tuned by Franco Gatti, one of the best, if not the best italian BMW tuner (he built BMW race cars. But he died a year ago.
(http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/th_IMG_9186online.jpg) (http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/IMG_9186online.jpg)
___________________
(http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/th_IMG_9188online.jpg) (http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/IMG_9188online.jpg)
___________________
(http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/th_IMG_9189online.jpg) (http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/IMG_9189online.jpg)
___________________
(http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/th_IMG_9190online.jpg) (http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/IMG_9190online.jpg)
___________________
(http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/th_IMG_9191online.jpg) (http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/IMG_9191online.jpg)
___________________
(http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/th_IMG_9192online.jpg) (http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/IMG_9192online.jpg)
Here is the mod list that magazine shows:
- lightened crankshaft
- CPS forged pistons, but not bored and not stroked, so oem displacement
- Schrick cams
- ported head, intake and exhaust holes, but not skinned
- Compression ratio 10,8:1
- flywheel lightened: minus 6,5kg from oem weight
- different oil pump, external oil filter and external oil radiator
- ITBs and airbox from 320iS E30 S14
- BMC CDA air filter
- Superprint exhaust, central and silencer pipe
- EFI race ecu, should be a standalone.
Power= 197hp at flywheel, 23,6 Kgm of torque (circa 168 ft-lbs).
rev limiter is slightly over 7000 rpms.
As you can see the e30 itb can be fitted!
To me the list is too short for 200hp...
no other infos of the car
Post by: nuvolarossa on June 18, 2007, 07:13:08 AM
Note that valves, hydraulic lifters, rods and more parts are stock unlike MM build...
and the CR is only 10.8:1 unlike 11.5:1 of MM rally engine!(http://i3.photobucket.com/albums/y75/nuvolarossa/host/318iselaborare/IMG_9191online.jpg)
:eek::biggrin:
Tell me what do you think!
Post by: Boyracer on June 18, 2007, 08:57:16 AM
Huh? How can it make that sort of power from stock displacement by revving only bit over 7000? :eek:
Torque has gone from stock 175 Nm -> 235 Nm which is over 130 Nm / liter!
Not even BMW Motorsport manage more than 105 Nm / Liter in S54 which was the last of M5X series motorsport engines. S54 has larger intake valves 35 mm vs 33 mm) and it too has ITB's, higher compression ratio etc. S50 3.0 which was from period of M42 managed even worse...
Integra type R with same displacement had torque of 134 ft lbs (182 Nm) which is barely over 100 Nm / liter.
Smells a bit fishy I must say, maybe dyno operator fiddled a bit with driveline loss correction? :)
Post by: Boyracer on June 18, 2007, 09:04:41 AM
Out of interest, I digged out some numbers from S42, race version of M42 used 1994 onwards:
S42/95 FIA 2.0 L 300 hp - 255 Nm BMW ECU
S42/96 FIA 2.0 L 308 hp - 260 Nm BMW ECU
S42/97 FIA 2.0 L 315 hp - 260 Nm BMW ECU
So best of them after 3 years of development got 130 Nm / liter, still bit worse than the civillian car on article :)
And those engines had everything optimized. Huge valves, top notch porting job, compression around 13:1, cams around 300 degrees, Alpha N...
Post by: nuvolarossa on June 18, 2007, 10:21:51 AM
Quote from: Boyracer;27971
Maybe it's very modded and the magazine listed only a little part of the engine mods? But it says that displacement is stock... and cr is only 10,8:1:eek::confused:
Post by: nuvolarossa on June 18, 2007, 10:25:34 AM
Quote from: Boyracer;27973
For what I can see this engine too is alpha n!
The tuner owned a BMW dealer and he worked and prepared race cars with S14s and S42s from 90 to 2004...
Post by: Boyracer on June 18, 2007, 11:40:42 AM
Well, 130 Nm / liter is possible as shown by the S42 race engine...  But I am bit sceptical same can be achieved on civillian car with those modifications. Maybe if it is really, really optimized (intake, exhaust, cam) to work on certain quite narrow rmp band.
Also there is few things that do not make sense. If you have custom pistons, why only 10.8:1 compressions? You could go safely up to 11.5 with pistons and gain more torque.
And why not rev the engine higher than 7000, certainly the engine could take it?
Also, only shrick M42 cam I know is mild 256 degree, unless it is completely custom made.
Need more info, that mod list really is bit too short to explain the torque :) :confused:
Post by: nobrakese36 on June 18, 2007, 01:19:21 PM
I have schrick 282's!
Post by: fliplap on June 18, 2007, 01:51:46 PM
Quote from: nuvolarossa;27978
That, or they got the power wrong. Tuner magazines regularly get details wrong, whether it be power numbers or mods. I suppose magazine don't regularly see the amount of outspoken criticism that a forum does over what could be considered a small mistake.
Post by: D. Clay on June 18, 2007, 02:58:19 PM
It would be some very good head work and as mentioned, could have a very limited power band. Not always a drawback for racing engines. I really like the strut tower brace and intake manifold fabrication. The special pistons could be for exotic fuel. The quick and dirty way to more power. The fuel especially is something that a magazine could easily be faked out by. This was crankshaft horsepower so the engine was on a dyno. This gives you a lot more to play with than RWHP actually in a car. You can cool intake air outside the building and all anyone sees is the duct work coming in. I've been around motor builders and they have a lot of tricks to juice the numbers on a dyno.
Post by: Alpine003 on June 18, 2007, 08:36:30 PM
Quote from: D. Clay;27997
Don't forget a non streetable idle at like 2k or something if his cam specs are some crazy specs.
The fan shroud is pretty cool. I don't think I've seen a deep one like that before and it appears to be a bmw part.
Title: Race engines are built for HP
Post by: Cristian G in Oz on June 18, 2007, 10:26:32 PM
Hey Boyracer,
Don't forget that the S42 ( and S14) race engines were built for HP not torque. When the engines rev high and make power you usually loose out in torque.
I know the S14 that I built for a group A M3 runs for power. It has nothing down low but really comes alive over 5K.
His custom pistons could be for exotic fuel "try Elf" but they could also be made to be much lighter than OE. A group A S14 piston looks nothing like a roadcar S14 piston and is light as a feather when compared.  We got 289hp at the wheels for our 2.3ltr Group A (1987 spec) S14. We could gain another 40HP if we swapped to the later DTM exhaust.
All this from an engine that is built to last. We can't afford to rebuild and retune after each round.
You are right the power and torque seem a little high but it may be possible, we just don't have enough info.
Cristian
Post by: 16v of Fury on June 18, 2007, 10:31:10 PM
Quote from: Cristian G in Oz;28041
Hey Boyracer,
Cristian
Wow, Cristian.
Can I send you the S14 out of my '88 M3... ?  I'd like to see another 100hp out of my motor, reliably!
:D
Post by: Alpine003 on June 19, 2007, 11:13:21 AM
Sounds like something you'd hear among the big 8 cylinder muscle cars and not normally associated with 4 cylinder engines.
Post by: nobrakese36 on June 19, 2007, 12:29:05 PM
S14 throttles converted to m42, old pics i have from some one who did it!
(http://i93.photobucket.com/albums/l59/nobrakese28/picthr.jpg)
(http://i93.photobucket.com/albums/l59/nobrakese28/throt2.jpg)
(http://i93.photobucket.com/albums/l59/nobrakese28/throt10.jpg)
(http://i93.photobucket.com/albums/l59/nobrakese28/throt9.jpg)
Title: Your right, but it's true
Post by: Cristian G in Oz on June 21, 2007, 12:16:50 AM
Quote from: Alpine003;28076
Your right about that. I couldn't believe the power loss when we started dynoing it.
We had to swap out the DTM style exhaust becasue when we tested the car the exhaust was to low to the road and would hit the track surface to much. We put the original Group A extractors back in and our loss before we retuned it was 40hp at the wheels.
Once we finished retuning it we got most of that back, but it cost us 4.5 hours of dyno time.
I can understand how the DTM M3s were getting significantly greater than 300 at the end of the E30 reign.
Post by: Alpine003 on June 21, 2007, 11:38:38 PM
Quote from: Cristian G in Oz;28185
By "DTM Exhaust", are you referiing to the shorter side exit exhaust that's basically like a "L" shape? Do you know if those had any type of Venturi designed into it?
Post by: Boyracer on June 22, 2007, 03:19:54 AM
Here's bit more about the guy:
http://www.elaborare.com/htm/top_tuner/Gatti.htm
Seems that he has worked with BMW March F2 formula cars at the time in addition to touring cars. Too bad I don't understand a word :D
Maybe some of out italian members could call him and ask about the details of the engine :cool:
Post by: SonomaGTLN2 on July 03, 2010, 10:05:49 AM
At the risk of reviving a 3 yr old thread, everything I have read about an M42 fitting s14 ITBs is that it can't be done because the overall intake port spacing is "over 3 inches" different...based on the pics in this thread, the spacing doesn't look bad at all...Just wondering if anyone knows of any developments over the past few years?
Post by: nuvolarossa on July 03, 2010, 02:49:54 PM
sorry I'm far from home where I have all my "technical data" :D
m42 bore spacing is 91mm
s14 is 100mm
but read here: http://www.e30tech.com/forum/showthread.php?t=78950
surely it can be easily done, but IMHO there are other better options.
PS: Jesus, my car is three years older than first post in this article! it's nice that I'm still in love with it :D
Post by: DesktopDave on July 03, 2010, 05:04:52 PM
I've always been wondering if we could fit some ITBs off an R1, Hayabusa GSX-R or Blackbird.  They flow enough air & fuel to support 200hp...with a standalone and a bit of alu welding...it'd be possible and it'd be cheap.
Title: Re: Italian E36 M42, NA 197hp, 168ft-lbs, E30 S14 ITBs...
Post by: Manndorfer on December 26, 2015, 04:17:35 AM
Sorry for Picking up such an old thread. But I am interested in taking the itb of the s14 on the m42. Please no questions, why I dont take the s50 or dbilas itb. It is very simple. In german race regulation it is only allowed to take intakes from e30. So the only way is the s14 itb.
Can you send me pictures from the modified itb with the adapter plate? And modifications of the airbox. (I read about modifications, because of the brake system).
Thank you very much.
A last question i have: how much power and torque you can make with the itb? We have with series itb m42 207hp and 220nm right now.
Post by: Warsteiner on December 26, 2015, 10:09:53 AM
Manndorfer,
The pics are on the bottom of page 1.
Cheers,
~Ralph
Post by: MoMansi on December 27, 2015, 01:08:52 PM
i had the S14b20 three times, great engine, had the 46mm ITBs , great power band, the ITBs from the S14 would fit with custom work of cutting ,machining and welding, however, bare in mind the S14 is a totally different engine in design and intend for use, the least things we can think of are the 93.4mm bore vs the 84-85mm in the M42/M44 engines, the 38mm intake valves vs the 35mm in the M42/M44, the air box size, the runners length... many variables here, i doubt the drivability  will be acceptable if done.
Post by: Freak on December 28, 2015, 03:59:08 PM
M42/M44 intake valves are 33mm.  :)
Post by: MoMansi on January 01, 2016, 07:41:02 AM
yeah 33mm thanks, cheers
Post by: MoMansi on January 17, 2016, 07:49:25 AM
sorry if i'm posting in an old thread but i don't understand the reason some people see it hard to get over 100 HP/litre, the S14B20 is a 2.0 litre engine and gets 211Nm@4900 rpm and 192HP@6900 rpm.
so where did BMW choke those engines either it's an M42 or M44?
Post by: MoMansi on January 17, 2016, 07:52:14 AM
another point, the S14B20 also had a 10.8:1 compression ratio, so nothing crazy, but it required RON98 for its aggressive ignition maps and no knock or O2 sensors, pure mechanics and engineering.... the M42/44 series has more modern tech than those S14 old motors, they are also lighter....
Post by: wazzu70 on January 18, 2016, 09:46:52 PM
The cams on the M42 are lacking. A good set of cams helps quite a bit!
