DISCUSSION => Engine + Driveline => Topic started by: gearheadE30 on May 31, 2007, 04:54:01 PM
Title: Timing equipment rebuild questions
Post by: gearheadE30 on May 31, 2007, 04:54:01 PM
WEll, now that school is almost over (YAY!!!) I'm trying to get geared up to do a timing system overhaul. Just as an idea of the condition, the engine has mostly highway miles but it has the original tensioner, guides, chain, gears, everything. And it has 200k miles.
My current plan is to take the intake out and clean it, remove the timing covers, cam cover, and t-stat cover as well as all of the parts needing removel to get to them. Then I will replace the guides, tensioner, and chain. I haven't taken a look at the gears yet, but I haven't been able to find new ones anyway. All new gaskets will go on as well as a new t-stat upon rebuild. I have heard many say that it is also good to check the oil pans, so I will be dropping the upper and lower pans to clean them and check for loose bolts and check the oil pump screen. New gaskets used there, too.
I'm not sure if I should remove the intake heater plate yet as I live in an area that gets down to about 5 degrees once in a blue moon. Any opinions? Pros/cons?
Depending on the amount of sludge, I may get the head cleaned, but I don't know if there is anything cost-effective to do while I am in there.
I know many of you have rebuilt engines, so any info regarding things to do while it is all apart or pitfalls I will run into would be great.
Hopefully I'll have some pics posted soon, I know everyone loves them ;)
Post by: D. Clay on May 31, 2007, 10:07:15 PM
I would drop the lower oil pan first. If there's no plastic or ground up metal, I would just replace the tensioner. You can see the cam gears and chain at the top. If the cam gears aren't pointedly sharp and the top of the guides look good, I would leave it alone. You probably have another 50,000 miles until you will need an engine anyway.
Post by: rhogg on May 31, 2007, 11:40:43 PM
So is pointedly sharp actually mean a point?
My upper cogs have a very thin flat top to them. - nowhere near as sharp as a bike cog, but also a long way from the chunky top of a new cog.  The car has 120K miles on it.  I replaced my tensioner but the one that came out looked quite new.  I do have that whooshing  noise from about 28/3000 rpm on up.
I figure this means get to it sooner rather than later but I'm ok for now.  Any thoughts?
Title: Whooshing isn't really the timing gear
Post by: Cristian G in Oz on June 01, 2007, 04:07:03 AM
Quote from: rhogg;26925
You might well find that the 'whoosing' noise is the engine driven cooling fan.
If your tensioner and chain are playing up you wont get a whooshing noise it will be more like a rattle.
Cristian
Post by: gearheadE30 on June 01, 2007, 03:42:35 PM
I eventually plan to do a more major rebuild, with high-compression pistons, shaved head, M50 lifters, schrick or similar cams, stuff along those lines. I just don't have the $$ right now and would like the engine to last a few more years until I do. Even then, I hear of a lot of people over on bf.c who seem to have more than 300k on these engines. Are they just lucky?
Title: How long, how long?
Post by: D. Clay on June 01, 2007, 04:19:51 PM
Quote from: gearheadE30;26949
It comes down to the type of use and the degree of maintenance. Flog the crap out of them and they won't last as long. Use good oil and change it regularly. On a rebuilt engine start with synthetic. Some people relate to them as old cars and just drive them.  The problem is that most E30's have been through about three owners by the time we get them and it's the rare one that has records.
Post by: sheepdog on June 01, 2007, 06:09:24 PM
Considering this, save your money.
Pull only the lower pan, and valve cover. Check for debris, tighten (and locktite?) the pan bolts inside, and check your cam gears. If they look worn at all (post a pic), replace the tensioner and close it back up.
No point in pulling the upper pan unless you have to replace the oil pump or timing chain housing. It is a hassle and will not accomplish anything. Nothing there. Anything inside will have made its way to the lower pan.
Save your money and just do your rebuild a bit sooner, doing what you are looking to do, is almost 1/3 the cost and the work of a rebuild.
Post by: gearheadE30 on June 02, 2007, 09:23:25 PM
Quote
My car does happen to have complete records, so I got lucky. It has been very well taken care of.
As for the future major rebuild, I'm still not sure what I am going to do. The naturally-aspirated rebuild with all of the custom work is a bit pricy, so I'm not sure yet. I want the engine to be as reliable as possible either way, as I am considering a DASC setup as it seems to be reliable, makes a lot of power, and is *fairly* chap compared to a complete rebuild. It really will come down to the shape my engine and wallet are in in about four years. That is the target time for something major...
Also, thanks for the info on the oil pan. Saves countless hours of letting oil drip  on my face...
Post by: rhogg on June 03, 2007, 09:24:38 AM
Good information guys, thanks.
Here is a picture of my upper cogs.  You can clearly see wear if you compare them to pictures of new cogs, but you can also see there are still flat tops on each tooth. I don't consider this "sharp" and with the abscence of hooking and rattles figure I still have some time.  Will pull the lower pan though and check it out next oil change.
Thanks again
Post by: gearheadE30 on June 03, 2007, 07:37:53 PM
This is what they are supposed to look like, although I'm not sure if this is an M42 gear
Post by: ak96ss on June 03, 2007, 07:50:59 PM
I would say those are getting pretty darn close to needing to be replaced, myself...
Post by: tjts1 on June 05, 2007, 02:38:20 PM
I took the valve cover to do the tensioner (not really necessary) as well as inspect the health of the cam sprockets. The engine has 139k miles with conventional oil change every 3k.
(http://farm2.static.flickr.com/1325/532111125_3394f6e480_o.jpg)
(http://farm2.static.flickr.com/1162/532111165_21c783df56_o.jpg)
I see a little bit of rounding on the edges but not as bad as the one pictured above.
(http://farm2.static.flickr.com/1412/532111203_7f8336c7e4_o.jpg)
Letting it soak in carb cleaner over night.
(http://farm2.static.flickr.com/1436/532111243_edee47669f_o.jpg)
Post by: gearheadE30 on June 05, 2007, 02:44:36 PM
Wow, that looks pretty good to me. Really hope mine looks that good when I do the preliminary checking this weekend...
Post by: rhogg on June 05, 2007, 08:32:57 PM
" I see a little bit of rounding on the edges but not as bad as the one pictured above. "....  Thanks for making me feel good!   ;)
Control arms arrived today  -  I guess the timing chain and sprockets are the next job.
Post by: gearheadE30 on June 10, 2007, 11:17:07 AM
Mine are very similar to the ones posted by rohgg. The problem is that it doesn't seem like there is any place to buy M42 sprockets online. Any help?
Post by: ak96ss on June 10, 2007, 11:25:52 AM
Get the part numbers from RealOEM then call BMA, or do a special order request on their webpage, BMAParts.com.
Post by: romkasponka on June 10, 2007, 01:45:43 PM
Quote from: rhogg;27158
I think this could be just different profile of tooth, or diferent height. If you look close enough you will see where metal is polished, and where machining pattern is left.
Post by: rhogg on June 10, 2007, 08:58:39 PM
Thats a good point.  It does look like it is just the valley and not the peaks that are polished.  I am due for a oil change so will take a closer look in a couple of weeks.
I have an oil ooze from the lower timing case, so I was going to take a look at that end as well.
Thanks for pointing that out!
As far as where to get these parts, you can order them from Pelican Parts as well.
http://www.pelicanparts.com/bmw/catalog/shopcart/BE30/POR_BE30_ENGcam_pg2.htm
http://bmwfans.info/original/E30/4-T/318i-M42/USA/L/M/1990/09/mg-11/ill-11_1191/
