DISCUSSION => General Topics => Topic started by: 16v of Fury on May 27, 2007, 10:12:25 PM
Title: Has Anyone Modded Their Stock Exhaust?
Post by: 16v of Fury on May 27, 2007, 10:12:25 PM
Have any of you modded your stock exhausts?
As in, cut off the stock muffler and welded a new one on... ?  IE. Magnaflow?
Post by: Abrax on May 28, 2007, 05:42:09 AM
Yeap!
Check it here:
http://www.e30tech.com/forum/viewtopic.php?t=37642&postdays=0&postorder=asc&start=15
Or just take a look :
(http://www.e30.kamieniwnetrze.pl/exhaust/nam42exhaust.jpg)
Post by: Alpine003 on May 29, 2007, 12:34:16 AM
I have a natural modification in terms of a very small rust hole in my muffler. Doesn't sound raspy and sort of sounds Ferrari-esque! :cool: ;)
Post by: 318kid on May 29, 2007, 03:42:45 PM
I've modded mine, everything is stock except for the muffler because theres a glass pack back there. (http://www.m42club.com/forums/images/smilies/biggrin.gif) The sound has changed alot, its got a nice burble at idle, but it just gets a little raspy at the top end. I like it and it's not too loud, ill try to get a sound clip soon.
Post by: e9nine on May 29, 2007, 03:57:01 PM
Quote from: 16v of Fury;26672
...remember driving my 318iS, it has a Magnaflow :rolleyes:
Post by: automatic on May 29, 2007, 05:01:53 PM
I have a dynomax welded on to my exhaust. Its a drastic improvement over the Bosal OEM equivalent muffler I had previously but its not a desirable sound in my opinion. Given the options out there I think this is the best bang for your buck, considering you are not going to get any noticeable power gains by going with a more expensive aftermarket setup.
Post by: 16v of Fury on May 29, 2007, 06:08:54 PM
Quote from: e9nine;26791
It does?  I didn't know that!
Did you just weld on a Magnaflow muffler?  Or build an entire system... ?
I was thinking about just welding on a replacement (as in, LOUDER + MORE FUN) muffler :D
Post by: oldtimer on May 29, 2007, 10:09:10 PM
Okay, I was not going to tell on myself in here but since we are talking exhaust I guess I will.  I took my entire exhaust system out, from the down "Y" pipe and replaced the entire system with 2 1/2 pipe straight back to the muffler.  The muffler is a "Dynomax" straight through designed.  Nice sound at idle, and while up shifting.  Man if you get on the gas it reminds me of an Indy car up shifting.  If only I was good with video I will get a sound check and post it.  By the way, the weight difference from the entire unit like the one posted to the what I installed.   The stock cats themselves weigh more than the entire system I installed pipe and muffler together. I will take photos and will post them tomorrown.
Post by: Shocker on May 29, 2007, 10:38:59 PM
Quote from: oldtimer;26818
 The stock cats
Theres only one Catalytic converter on E30 M42.
Post by: Alpine003 on May 29, 2007, 11:06:17 PM
Call me old or something but unless my car is somewhat fast or powerful, I feel embarassed if I had a loud system and no power to back it up.
I'd rather have a quiet system so if I beat some Honduh ricer, it makes them feel that much worse thinking I had a stock drivetrain. At the same time if I'm really trying to beat someone off the line and lose, it's a saving grace knowing the other driver might not have been sure if I was really trying or not based on the quiet sound.
Now on the other hand, if a performance muffler really gave 10hp or more on our m42 motors, I might have to think about it...
As for the weight issue, I don't run any rear speakers, seat belts, and spare tire. I run a smaller battery and the Slime kit is pretty handy. Some of that is obviously gained back by my rear wing. ;)
Post by: e9nine on May 30, 2007, 08:06:24 AM
Quote from: 16v of Fury;26799
It's just a muffler welded on.
Quote from: Alpine003;26823
OLD MAN :D j/k I see where you're coming from. My car scoots somewhat proportional to the noise level.
Post by: gearheadE30 on May 31, 2007, 04:38:26 PM
I have a Bosal "OEM replacement" but it is REALLY loud and raspy plus it has a rattle at 3k rpm. Looking into a Supersprint cat-back as it is the best sounding one I have heard.
Out of curiosity, does anyone have a full dual exhaust? I know it is a bit useless on a four-cylinder, but was ondering how the sound was. In fact, an   E30 325is or *maybe* an M3 system might fit. Any ideas?
Post by: K V N on May 31, 2007, 05:31:59 PM
What is the size of the stock piping, is it 2.25?
Post by: jpod999 on May 31, 2007, 10:45:13 PM
I think so.
Post by: gearheadE30 on June 01, 2007, 03:32:08 PM
Yes, it is 2.25 all the way through
Post by: nomad on June 01, 2007, 08:49:39 PM
So is the nasty lump after the cat supposed to be a resonator?
I's say the longest possible resonator would work much better.
Post by: oldtimer on June 01, 2007, 10:29:09 PM
HELP...After posting to this thread and explaining what I have done to my exhaust I got very curious how it really sound.  So I had my daughter drive the car and gave her specific instruction when to shift as I drove behind her in my Boxster.  OH MY ####... my car sounds like a "RICER".  Please help me find another muffler to install so that my car does not sound like some high school boy's car down the road.
The cat and resinator does not exist in the car anymore.  I have 2 1/2 pipe straight to the muffler.
Post by: Alpine003 on June 01, 2007, 11:05:25 PM
Quote from: oldtimer;26968
I would get the longest resonator that you can fit in the straight section of the pipe welded on. Make sure you get the perforated tube version and not anything that is louvered.
Both Summit and Jegs sells some decent pieces that I have used in the past. I believe the secret to most N/A 4 cylinder cars is to have 1 resonator and 1 muffler in the entire exhaust to make it sound decent.
The only decent n/a 4 cylinders that I've heard to date without a resonator in the exhaust path are the Subaru boxer motors.
Post by: e9nine on June 01, 2007, 11:07:15 PM
That's the reason why right there. I have posted a vid of my car with the magnaflow on youtube on here. Do a search and listen to it. If your car sounds anything like that I'll send you money for a case of beer. If your car doesn't sound anything like mine, you deleting the resonator (primarily) and the cat contributes to you cars sound. 4 cyl sound==ricer sound most times (sans e30m3) so there you go :eek:
Post by: oldtimer on June 02, 2007, 07:43:59 AM
Gentlemen thank you for the input.  I will make that as my priority this week end.  As far as the Vid.  How do I view the vid in "Youtube"?  Do I have to join the site to view them?
Post by: ducatipaso on June 02, 2007, 11:02:09 AM
QFT. Performance systems do not need to be loud. I'd much rather have a nice, near stock volume with a deep sound any day.
Post by: christophbmw on June 02, 2007, 12:17:18 PM
im not old and im on the same page as you:) .
Post by: RustyTheDriver on December 01, 2007, 09:07:09 PM
Quote from: gearheadE30;26906
I have the same question myself. Is it possible to get a kit for a straight 6 and just use the pipes from the cat on? I'd like to have that dual exhaust look and if it was backed up with a good sound that would be great. Any suggestions?
Post by: gearheadE30 on December 02, 2007, 11:31:57 AM
I took a look under my car awhile back before purchasing the same Magnafolw that E9nine has and decided it wasn't worth it. An NA M42 doesn't really need any larger piping than the 2.25 that is there from the factory. With a supercharger or something, that would change, but nothing else would need it. All you would have to do though, is cut off the bottom part of the header at the furthest point that still has 2 pipes. Our headers are 4-2-1 instead of 4-1 because the factory wanted to give it more low-end torque. 2 custom pipes would then have to be made to meet the 325 or M3 exhaust. I'm not sure if there would be any fitment issures, but the floor stampingws are the same so it shouldn't be a problem.
Post by: longms on December 03, 2007, 02:47:43 PM
For all you guys out there using a magnaflow muffler, did you take the resonator out of the catback or did you leave it in?
Will the deletion of resonator be too ricer-ish? Would it take away the Euro sound of the car???
My exhaust is shot and have bought the new muffler and am having new catback built. Does anyone know of a replacement resonator that could be put in place of the current one? Or are they not that expensive anyways?
Post by: J///MR on December 03, 2007, 03:35:46 PM
Quote from: longms;38818
I left the stock cat and resonator in mine.  To me, most of the exhaust noise seems to come from the headers anyway.  I would think without them, that it would sound extra buzzy.
Here's a pic of my magnaflow.
(http://i63.photobucket.com/albums/h141/apiary009/for%20sale/IMAGE_092.jpg)
Post by: longms on December 04, 2007, 02:32:56 PM
Does it sound quiet but upon standing on the gas your car comes to life so to speak???? I want it to be a little louder than stock but keep a nice Euro sound too.
Post by: J///MR on December 04, 2007, 03:10:14 PM
Quote from: longms;38888
It's relatively quiet.  This is my first 4 cyl. bmw, purchased with a broken muffler, so I don't have too much of a reference point.  It doesn't sound particularly good or bad to me, it just sounds like a 4 cyl. motor.
I can definitely hear exhaust noise when I get on it though.
Post by: gearheadE30 on December 04, 2007, 04:01:39 PM
assuming that is part number 11265, it is the same muffler i have. It is loud above 2500 and below 3200, but everywhere else it is great. Granted, I do need a new cat and the resonator is a bosal one that is tiny and probly doesn't do much. It does have a bit of rasp when it is cold, but is great once it warms up.
