DISCUSSION => Engine + Driveline => Topic started by: ten2doyle102 on April 25, 2007, 04:14:28 PM
Title: Loss o power!!!
Post by: ten2doyle102 on April 25, 2007, 04:14:28 PM
Anyways, i was down visiting another dude with an e30 and  pulled a massive burn out and now when i accelerate i feel a very slight vibration only in 1 gear. did i do something to my diff or is the tire just flat in areas.
Also...how does one do a compression test?  i know that it is a retarded question but i have never done it and i want to do it properly.  Just need to know what i really need thanks
Post by: D. Clay on April 25, 2007, 05:18:21 PM
Get hold of a compression tester. It's a gauge on a hose with a spark plug threaded fitting on the other end. Screw it into the spark plug hole and crank the motor. There is a little button to reset the gauge back to zero.
The vibration could be guibo, differential mount bushing, motor or trans mounts, and stuff like that.
Post by: ten2doyle102 on April 25, 2007, 07:03:00 PM
ok thats what i thought.  i dont know whats doing it but its a bit annoying.
Post by: b318isp on April 26, 2007, 07:08:31 AM
Quote from: D. Clay;24505
Remove all plugs and pull the fuel pump fuse! Read after a fixed amount of cranks (5-6).
Post by: Pedro on June 23, 2007, 09:56:41 PM
What number would the fuel pump fuse be?
