DISCUSSION => Exterior => Topic started by: denious on April 12, 2007, 10:56:11 PM
Will these be bolt-on?
http://cgi.ebay.ca/15-BLACK-WHEELS-RIMS-4-LUG-CIVIC-XA-XB-SATURN-ION-SC-SW_W0QQitemZ260105419076QQihZ016QQcategoryZ43957QQrdZ1QQcmdZViewItem
And I don't care if you don't like them, so please save it. :rolleyes:
It's the right lug pattern...those look a lot like mine, the spokes are a deeper black though.
you'll need spacers. anything between 5 and 15mm would do the trick.
What does 15"x6.5" mean compared to 15"x7"? Basically, will those wheels fit 205 tires?
TMS have H&R 8mm spacers for $60 a pair without the bolts, and SportCompactOnly (http://www.sportcompactonly.com/Eibach/Wheel-Spacers/Wheel-Accessories/Wheels-Tires/part_c-121_b-96_pl-3146_p-1020.htm) have Eibach 8mm + longer bolts for $59. Anybody know if those would be all right?
Also, I need spacers for the front wheels too, correct? What I thought of getting as tires is 205/55R15, that won't rub anywhere?
I remembered from my previous post about Sportmax wheels (http://cgi.ebay.ca/SPORTMAX-BLACK-002-15X8-EURO-WHEELS-BMW-M3-E30_W0QQitemZ290104743856QQihZ019QQcategoryZ43955QQssPageNameZWDVWQQrdZ1QQcmdZViewItem). 0 offset, 15x8 and 195/50-15 tires recommended. Suits me perfectly especially if they're bolt on. So... Are they? ;) There're also the same Sportmax with +15 offset. (http://cgi.ebay.ca/SPORTMAX-BLACK-501-15X8-15-OFFSET-EURO-WHEELS-BMW-E30_W0QQitemZ290104743922QQihZ019QQcategoryZ43955QQssPageNameZWDVWQQrdZ1QQcmdZViewItem)
15x6.5 is 6.5" wide 15x7 is 7" wide. whatever you do dont get the 15x8 et0 they will stick out of your fenders almost an inch. 15x8 et15 would be a great fit as long as you can get some negative camber to avoid rubbing the fenders. 195's are way too narrow for an 8" wheel. 225/50/15 is the right size for those.
Will I still need spacers though? Because if I do, I just don't understand what criteria do I search for to not have to get them... Also, the negative camber should be done on all or just front wheels? And what will I need for the camber angle to be ajdustable (or only telling the alignement dude what I want)?
ok,
off the top of my head, the offset should be such for optimal fitment:
6" wide wheel et30-40
6.5" et25-35
7" et20-30
7.5" et20-25 (Fender rolling suggested)
8" et17-20 (fender rolling and added negative camber suggested)
You can see that as the wheels get wider, you have a smaller window for error.
In the rear, negative camber is increased as a result of lowering, in the front you will need camber plates to replace your strut mounts.
So when do you need spacers? If you have a 7" wide whee that has an offset of 40mm you will need a 10-20mm spacer to get the offset down to the recommended window.
Ok, so 15x8" +15 offset with 225/50R15 on stock height ride without camber plates in the front should work fine for about a month without damaging anything? Then I'm getting a garage to do the work myself, hence I thought of getting these (http://www.turnermotorsport.com/html/detail.asp?PRODUCT_ID=RE1619). Should 3/4 be enough?
you will damage your fenders if you hit any bumps large enough to cram the tire into the fender while the wheels are turned.
3/4 degrees isnt very much. Ireland engineering has a similar product that gives 1.25 degrees. That would do the trick.
*sigh* All-in-all it comes to around $900 Northern-American dollars with dirt-cheap tires lol :( But the setup would be very nice methinks. Thanks for all the help!
I like them! Any idea how much they wiegh?
Which ones are you talking about exactly?
