DISCUSSION => Electrical => Topic started by: Cristian G in Oz on April 03, 2007, 10:11:56 PM
Title: Another way of getting ECU codes?
Post by: Cristian G in Oz on April 03, 2007, 10:11:56 PM
Does anyone know how to get codes out of the ECU when your car is not fitted with a check engine light or don't have a code reader?
Can anyone tell me which pins in the diagnostic port have the code out signals.
I want to check if any codes are stored in my ECU but can't be bothered taking it to a service joint just to have them plug in their tool, if I can do it!
Failing that does anyone know of a cheap tool or a DIY tool that you can use?
I know these are some big explanation questions, but any info would be appreciated.
Thanks guys.
Cristian
Post by: bmwman91 on April 03, 2007, 10:15:43 PM
You could always find the pin that fires the check engine light and hook up a small bulb between it & the ground with a .5A fuse?
Post by: Cristian G in Oz on April 04, 2007, 02:50:56 AM
Quote from: bmwman91;22864
Now thats a good idea. I didn't think of that.
Anyone know which one it is? I'm guessing you mean the one from teh ECU or dash not the diagnostics port....
Cristian:)
Post by: Vladi on April 04, 2007, 02:43:00 PM
What pin was that again? :D
Post by: Whitey on April 09, 2007, 03:56:47 AM
I used to be able to check the fault codes using the blink code system on a previous E30. With the ignition switch on and the engine not running press the accelerator pedal to the floor 5 times in less than 5 seconds. The check engine light stays on for 5 seconds then begins flashing the first fault code. the light flashes once for one, twice for two, etc. There is a 3 second gap between digits. There are four numbers for each fault code, and you need a sheet to determine what the codes apply to. Once the whole code has been displayed the light will stay on for 3 seconds before moving to the next fault code (if any). if the first code is 1444, it means there are no faults stored. Not sure if this works on 318is I haven't tried it yet.:confused:
Post by: doigal on April 09, 2007, 06:44:01 AM
Quote from: Whitey;23264
snip
OP asked for a way without using the check engine light. I'd be interested in this as well, i dont think many AU spec e30s have one.
Post by: m44power on April 09, 2007, 08:15:27 AM
this engine light can work on e36's m42 and m44 ? in our cluster we have one free engine light and cars only with OBC use em
Post by: m44power on April 09, 2007, 08:18:23 AM
By the way ECU Pin 8 is the pin for the check engine bulb
Edit: Just to be more precisly motronic 1.7/3.1 pin 8
Motronic 1.2 pin 15
Post by: Whitey on April 11, 2007, 08:27:52 AM
Sorry misread. Had a guy show me this before on previous car, and I only remember the 1444 code. :(
Post by: bmwman91 on April 11, 2007, 12:42:52 PM
Anyone have any luck pulling the codes?
Title: what about any other wires?
Post by: Cristian G in Oz on April 16, 2007, 10:01:51 PM
Quote from: m44power;23275
Motronic 1.2 pin 15
Does the other end go to earth or does it have t go through a circuit on the guage cluster?
If it just oges to earth then it should be easy to rig up a "check light".
Title: not yet......but working on it
Post by: Cristian G in Oz on April 16, 2007, 10:04:32 PM
Quote from: bmwman91;23532
bmwman91 - I haven't go round to it yet.
I had to work last weekend at the track, timing another marque. It is so boring when there is only 1 E30 going round and even it is not an M42.
Post by: m44power on April 17, 2007, 05:36:47 PM
Quote from: Cristian G in Oz;23910
it goes to bulb (earth)
