DISCUSSION => Electrical => Topic started by: iplayfront11221 on March 19, 2007, 11:49:43 AM
hey all i am looking for a chip for my 1998 318i and most the chips out there are for older years what years will fit my car or will anby of them thanks
you will need one for the m42. The early 318's had the m10. There are quite a few chips out there for you to choose from. The "best" is the markD chip according to most people. Thats going to run you above $200 new. The cheap route is the ebay chip. Thats a road that seems to be pretty controverial [spl?]. I personally have one in my car since it came on the car when I bought it. But I also have the stock chip and I deff like the ebay chip over the stock one. I will be installing MS soon so I will have that up for sale sometime.
Hope that helps some
so any chip for the m42? should work?
ummm....I'm not sure about the e36 m42 chips? Maybe someone will chime in
ok thanks for the help and if possable does anyone know what years have the m42 thanks
up...anyone know what years chips will fit my car? thanks
so would a chip from a 1994 318i fit in my 1998?
You're better off verifying via TMS, Bavauto or any vendor who sells chips for e36 m42s. Just call them and make sure you know if you have an m42 or m44 in your car. If you don't know which engine you have, have your vin # ready when you call them or simply check on http://www.realoem.com/bmw/select.do by entering the last digits of your vin as instructed where it shows serial number (http://www.realoem.com/bmw)
G.luck
mine has a m44 if that helps any
you said your car was a 98 right? that should be obdII wich means you are going too too be looking for somebody to reflash your ecu.
