DISCUSSION => Engine + Driveline => Topic started by: steve321 on March 03, 2007, 03:09:46 PM
(http://i34.photobucket.com/albums/d117/stevemitchell321/ITBsonhead1.jpg)
(http://i34.photobucket.com/albums/d117/stevemitchell321/ITBsonhead4.jpg)
(http://i34.photobucket.com/albums/d117/stevemitchell321/ITBsonhead3.jpg)
(http://i34.photobucket.com/albums/d117/stevemitchell321/Photo-0037.jpg)
(http://i34.photobucket.com/albums/d117/stevemitchell321/ITBsonhead7.jpg)
(http://i34.photobucket.com/albums/d117/stevemitchell321/PICT0005small.jpg)
(http://i34.photobucket.com/albums/d117/stevemitchell321/PICT0009small.jpg)
will post info later, busy at the mo tho
steve
________
MAINE DISPENSARIES (http://maine.dispensaries.org/)
yes details!!!
looks great, please post up some details in the stickied ITB thread :)
Looks very nice!
great job
wow!
what kind of ITB's are you using?
he is using s14 itb e03 m3
No he's NOT!
He is using Euro E36 m3 throttle bodies, the two engines have the same cylinder spacing.
The S14 has a bigger cylinderspacing, and will not fit unless an adapter plate is made.
Sweeeeeet. :D
No he's NOT!
i looked at my itb and you are right that is not a e30 m3 ITB
how are those itb's being held onto the head?
clamped on the top, bolted on the bottom.
It looks like he didn't use the adapter plate after all.
i did have the adapter making them fit for about 6-8 months, but did'nt like having the adapter plate, it made the air/fuel go round quite a tight corner, and i felt it was a restriction.
steve
________
Fisting Lesbian (http://www.fucktube.com/categories/574/lesbian/videos/1)
so can you share some more details? like what engine managment, power gains ect.
i'm using megasquirt, but its not fully up and going yet, i have been using the standard motronic for a while on it now, and its not too bad, not sure about gains, it feels much much better put it that way, but generaly ITBs on there own dont always give you much more bhp, i think there more the type of thing that when coupled with wild cams, and my new ported (and bigger valved) head, then i expect to see some good gains, i want over 200bhp, but i think that may need the CC to be increased abit, i am going to work on the bottom over the summer, and i'd like it to rev very high, i'm thinking 8500-9000
steve
________
18HotG4ASS (http://www.girlcamfriend.com/cam/18HotG4ASS/)
hey steve, nice to see you on here.
post up some pics of this new head of yours!
my opinion is that you will never, ever see anywhere near 200bhp from the head work, cams and ITBs. sorry :(
when you gonna finish MS? you should focus your energy on that mate, you're gonna run lean as hell with all these mods and the half-working motronic.
steve
hmmm, thats nice that it works with motronic. did you just hook the itb tps to the eninge wiring harness? you dont have an afr gauge do you? I also see you are using an afpr, did you have to mess with that or is it on stock pressure? stock afm or maf?
i wonder if the guys at miller performance could make a tune for it.
thanks
lol i'll answer for steve. he runs without the TPS :O and has trouble when jabbing the throttle but apparently not too much at other times. Steve has a NB02, i've been telling him for a long time to buy a wideband, but he's an engineer at heart and more enjoys the fabrication stuff!
from personal experience, this isn't the way i'd run it. I don't think Steve intends to for the long term either. as a late e36 it should have good lambda feedback to make sure AFRs aren't too dangerous.
That is gorgeous!!!!
In http://www.vimota.lt stock head, custom valve springs, solid cam followers, titanium springs plates, camshafts about 300 deg, stock compresion ratio, ITB, aftermarket ECU and stock bottom they get about 190 hp. I'll try to get dyno graph.
They had only one serious problem. The stock oil pump start to cavitate at about 8000rpm.....
So ;)
well i will be dissapointed if when i put the modfiied head on i dont see 180bhp minimum. but 200bhp+ is more a long term goal, i know i probably wont get that right now, but when i bottom end is done i hope to
steve
________
Vape Info (http://johan-luis.tumblr.com/)
let's both do a r/r together when you're up and running steve, will be awesome.
romkasponka, let's have some more details of that one making the 190bhp!!
i've heard of one getting 190bhp before with just cams, itbs and remap,
________
Ipad guide (http://ipadguides.info)
How do these TB's look from the cylinder head side? Can they be matched to the M42 intake gasket? Also, it appears that the injectors fit in the TB housing. Is this correct?
Nice set-up and nice e36 . :D
What are you running for upper strut mounts ?
I'd like to have them just for the way they look!
Is'nt that an e36 body? Never mind I see it now!
