DISCUSSION => Swaps, Turbos, Buildups => Topic started by: asubimmer on February 22, 2007, 12:47:48 AM
Has anyone tried to use a m20's TB on a m42 IM? I am going to be installing the MS as soon as I get it and build it and I plan on trying to use a m20 TB w/ a mustang TPS.
ttt
I guess I may find out in a few days if it'll work
Seems like you'd be trying to fit a square peg in a round hole. I think the adapter you would need to make it fit and flow properly would be very thick and complicated.
I think it would be easier to adapt a megasquirt friendly TPS to the stock TB.
your right I think fabin an adapter plate might be too much work. Maybe the mustang TPS will work on the m42 TB? Any ideas? Bahh I hate the oval of the m42 TB lol
What is wrong with the M24 TPS? It calibrated and worked fine with the MS I ran. I was running Megasquirt 1 with the -Extra code though...don't the newer versions allow for TPS calibration as well?
I was under the impression that the M42 TPS wasn't a %?
