DISCUSSION => Electrical => Topic started by: Forwox on July 03, 2017, 04:37:54 AM
Hi, there! New to this forum and quite new to M42.
I am doing M40 year '91 NO EWS to M42 year '95 DISA + EWS II swap in my brokatrot E36 sedan. But I need a quick tip about electrics.
This Blue+Yellow with Green+White 2 pin connector cable goes out together with starter cables in 1st section under intake manifold of wire clunk, it's quite long about 0,7m. [Picture 1.] Does it is related to EWS II? Everything else is connected. Disa valve, idle controller, charcoal filter, oil filter housing sensor also, all places where 2 pin connector can be.
It looks like 1st wire in wiring diagram attached below. [Picture 2.]
Would be very thankful for any help. :)
(http://lejup.lv/thumbs/595a101ebfdeayhyfinz1499074591.JPG) (http://lejup.lv/viewer.php?id=595a101ebfdeayhyfinz1499074591.JPG)
(http://lejup.lv/thumbs/595a101ebfdeauxduwpk1499074590.JPG) (http://lejup.lv/viewer.php?id=595a101ebfdeauxduwpk1499074590.JPG)
Should be an engine function. EWS is under dash / keyring etc.
You can get a copy of the ETK here:
http://wedophones.com/Manuals/BMW/ (http://wedophones.com/Manuals/BMW/)
