DISCUSSION => Engine management => Topic started by: m42roundie on September 20, 2016, 07:03:09 PM
Title: e30 m42 "175" ECU variations, how to decode white label ?
Post by: m42roundie on September 20, 2016, 07:03:09 PM
Ok, New to the forum and hoping to harvest some technical ifo from those in the know, here goes.
I have done a lot of searching and have found no info here or on the internets regarding the 90-91 318i / 318is "175" ECUs and the variations. Does anyone know how to decipher the white labels / stickers on the case?.
I have 4 1991 "175" ECUs but they are all slightly different inside, meaning slightly different circuit board layouts.
In other words they all have the same part number and all came out of 1991 318 series cars but are all different from one another. One unit even has a an additional circuit board standing on pins above the main board. what gives?
Can anyone shed light on this??
Thanks!-     Jeff
Title: Re: e30 m42 "173" ECU variations, how to decode white label ?
Post by: 1998ccc on September 20, 2016, 08:08:02 PM
Not sure if it's a typo, but the "173" DME is for the M20 i motor.  The had quite a few different #'s and  single / two board styles for the i cars.  153 was 2 board, 173 / 380 / 525 etc were a few of the #'s that come to mind for the i's.
Title: Re: e30 m42 "175" ECU variations, how to decode white label ?
Post by: m42roundie on September 20, 2016, 11:27:44 PM
DOH,   typo indeed... now corrected!   thanks for the heads up!
Post by: wazzu70 on October 10, 2016, 12:07:35 AM
If the PN is the same the ECUs should have the same functionality. If parts are not reverse compatible they will change the PN for tracking reasons.
The differences in PCB variations could be they are supplied by different manufacturers (different ways to get same end result), slight improvements, or changes due to part unavailability.
