DISCUSSION => Interior => Topic started by: Froos on May 17, 2016, 05:26:45 PM
Title: Oil pressure and temp sensor location
Post by: Froos on May 17, 2016, 05:26:45 PM
A T or Y connector wont do, since the temp sensor wont be in the flued stream, according to vdo...any thought on where to put these sensors?
Title: Re: Oil pressure and temp sensor location
Post by: Darky on May 18, 2016, 12:25:44 AM
What's the application turbo?
There's a spare Bung on the front of oil filter.
Post by: Froos on May 19, 2016, 04:47:03 AM
You mean rhis one? Any idea on its size of the threat?
Post by: Darky on May 19, 2016, 05:34:49 PM
Yes that's it just above and to the right of the arrow. Allen key required!
M10 thread from memory, but don't quote me.
Post by: Froos on May 22, 2016, 03:18:21 PM
Thanks man!
Post by: Delta on May 28, 2016, 11:56:05 AM
Both the front hole (pictured above) and the port where the stock oil pressure switch is mounted are 12x1.5 thread. I ended up using the front port for my bro pressure sender and the rear port for my temp sender. Worked perfect for me!
Post by: Froos on May 29, 2016, 11:52:54 AM
Thanks i figured it was 12,5 to bad i have vdo meter so sender is expensive but ordered
