DISCUSSION => Engine + Driveline => Topic started by: Timber on October 16, 2015, 09:53:52 PM
Hi, I bought the m42 timing chain kit from fcp euro and one of the tensoiners doesn't look like the same one that I pulled from the engine. The old one has rubber grommets and had a casing that covered it, but the new one has threads and the case doesn't fit correctly. Is this a upgraded design? I included pictures to show what I am talking about. The piuctures can be found here https://drive.google.com/folderview?id=0B93SQbaRSt20SVUwMGpUV3NFOG8&usp=sharing (https://drive.google.com/folderview?id=0B93SQbaRSt20SVUwMGpUV3NFOG8&usp=sharing)
Thanks for your help
That is a design change; although, it was done some years ago and is shown in the Bentley manual directions. That threaded barrel at the end is there to compensate for any differences between the block mounted lower timing case and the head mounted upper timing case. Just torque the lower 3 bolts that hold the guide on and then adjust the barrel so that it just seats on the upper timing case. Then insert the bolt and torque it down. Loctite if you have any available, but not required AFAIK.
