PAPER OR PLASTIC => For Sale => Topic started by: Nate.Vincent on April 21, 2015, 01:18:04 PM
Title: Lots of engine parts for sale m42 & m44
Post by: Nate.Vincent on April 21, 2015, 01:18:04 PM
Doing some serious spring cleaning and I have a lot of M42/M44 parts for sale.
-m44 cylinder head 120k cams out but I have all the parts.  Two slightly tweaked valves otherwise heads in great shape.
-m44 cylinder head 160K all complete.  Ready to bolt on looks like it was surfaced once before.  Probably could use a valve lap.
-m42 cylinder head 200k with just valves.  Two slightly tweaked valves. Has sat around for a while and will need rebuild/clean up.  Have separate set of cams if needed.
-m44 block
-m44 rods
-m44 pistons
-m42 block (a little rusty)
-m42 crank (a little surface rust)
-m42 rods
-m42 pistons
-m44 flywheel and clutch (98 318ti)
-2x m42 intake manifolds upper portion
-2x m44 intake manifolds both sections
-3x m42/m44 throttle bodies
-exhaust headers and down pipes from e30 and e36
-318ti radiator
-e36 oil pan
-e36 obdII harness uncut
-e36 obdII harness relays cut off
-e36 DME with stuff for ews
-3x valve covers
-e36 m44 auto transmission also z3
I have various other parts.  Please ask if you are looking for something m44 or m42 related.  If interested please email me at natevincent101 at gmail dot com as I don't frequent this site often.  Please make offer on parts.  Located in Connecticut.
pics:
(http://i5.photobucket.com/albums/y152/needle332rur/parts/IMG_22901_zps34i5lugx.jpg) (http://s5.photobucket.com/user/needle332rur/media/parts/IMG_22901_zps34i5lugx.jpg.html)
(http://i5.photobucket.com/albums/y152/needle332rur/parts/IMG_22871_zps3m90yxug.jpg) (http://s5.photobucket.com/user/needle332rur/media/parts/IMG_22871_zps3m90yxug.jpg.html)
(http://i5.photobucket.com/albums/y152/needle332rur/parts/IMG_22841_zpsf5ztqoq9.jpg) (http://s5.photobucket.com/user/needle332rur/media/parts/IMG_22841_zpsf5ztqoq9.jpg.html)
(http://i5.photobucket.com/albums/y152/needle332rur/parts/IMG_22831_zpsdjwdr3j0.jpg) (http://s5.photobucket.com/user/needle332rur/media/parts/IMG_22831_zpsdjwdr3j0.jpg.html)
(http://i5.photobucket.com/albums/y152/needle332rur/parts/IMG_22821_zpsoobkgyjo.jpg) (http://s5.photobucket.com/user/needle332rur/media/parts/IMG_22821_zpsoobkgyjo.jpg.html)
(http://i5.photobucket.com/albums/y152/needle332rur/parts/IMG_22811_zpsb4uceoh3.jpg) (http://s5.photobucket.com/user/needle332rur/media/parts/IMG_22811_zpsb4uceoh3.jpg.html)
(http://i5.photobucket.com/albums/y152/needle332rur/parts/IMG_22731_zpscmst5dkd.jpg) (http://s5.photobucket.com/user/needle332rur/media/parts/IMG_22731_zpscmst5dkd.jpg.html)
(http://i5.photobucket.com/albums/y152/needle332rur/parts/IMG_22721_zpsojj9qcou.jpg) (http://s5.photobucket.com/user/needle332rur/media/parts/IMG_22721_zpsojj9qcou.jpg.html)
(http://i5.photobucket.com/albums/y152/needle332rur/parts/IMG_22701_zpsxevw6ffb.jpg) (http://s5.photobucket.com/user/needle332rur/media/parts/IMG_22701_zpsxevw6ffb.jpg.html)
(http://i5.photobucket.com/albums/y152/needle332rur/parts/IMG_22691_zpssbao0198.jpg) (http://s5.photobucket.com/user/needle332rur/media/parts/IMG_22691_zpssbao0198.jpg.html)
Title: Re: Lots of engine parts for sale m42 & m44
Post by: fiftytakedowns on April 22, 2015, 01:14:34 PM
Do you have a 91 318 engine, transmission, driveshaft  and harness?
Post by: amcink on June 18, 2015, 12:49:49 AM
Prices on the M44 heads?
