DISCUSSION => Engine + Driveline => Topic started by: thefrog1394 on April 07, 2015, 07:40:55 PM
Prefacing this: I've searched and haven't found any resolved threads :)
1991 318i. When I start the engine I get a rough/bouncing idle and usually a stall. After about 20 seconds the engine runs perfectly. Completely stable idle. (This to me rules out vacuum leak or idle control valve). Not a cold start issue because as soon as I shut the car off it will do the same thing upon restart. Any ideas?
Fuel pump, fuel filter, fuel pressure regulator, crank position sensor?
