PAPER OR PLASTIC => For Sale => Topic started by: e3091318is on January 06, 2015, 08:26:57 AM
Cam Shafts (intake/exhaust) Hot tanked, cleaned, and air compress dried. No rust or major wear. $100 shipped.
WPS Starter - $40 (tested and does work)
Spark plug wire tray holder - $15
Set of timing chain gears (upper cam shaft gears) - $35
Rear main seal housing - $15
Crankshaft Main bearing caps (5) - $25
Radiator Coolant Temp Sensor - $20
Cam Shaft Trays (hot tanked, cleaned) comes with holders on top for cams - $35
Fuel Injectors (should probably be serviced while out but worked as intended) - $40
bump.
What year car are these from?
1991
would you have an engine harness ?
No sorry
I'm interested in the camshafts w/ caps and trays if they are still available. Are you willing to ship?
