DISCUSSION => Engine + Driveline => Topic started by: nickmpower on January 09, 2007, 11:59:47 AM
Title: spacer for m20 flywheel has more then 1 use!
Post by: nickmpower on January 09, 2007, 11:59:47 AM
well you all know that the bolt protector thing from the m42 fly is supposed to be used between the crank and m20 flywheel so it flywheel doesnt hit the oil pan. Well i have a nice JB racing flywheel and i checked and it didnt hit the pan with out the spacer. so i thought why not leave that unbalanced POS out. Well after i got the engine in with the tranny i turned it over by hand with some oil in the chambers to get them coated because i wasnt able to finish it up before i had to leave for santa clara. any ways there was a grinding noise that i wasnt too fond of. I was bummed because The flywheel actaully did hit or something. Well i took out the starter and the noise was gone!!! so i guees i need to make some sort of a spacer for the starter. would a couple grade 8 washers be good enough or would it not have enough support?
Post by: kowalski on January 09, 2007, 01:39:20 PM
that would be fine, tho it might be to agressive of a move. you could try starter shims from a chevy or something...?
Post by: nickmpower on January 09, 2007, 11:33:42 PM
naw, it needs to be at least the thickness of the spacer
Post by: bmwman91 on January 10, 2007, 10:03:33 AM
Without the spacer, isn't there still the issue of the TOB not being able to fully disengage the PP from the clutch disc?  Shimming the starter seems a little risky as well...that leaves a gap for water to possibly creep in up there, no?
Post by: Alpine003 on January 10, 2007, 11:10:20 AM
Quote from: nickmpower;17221
If you use washers for the starter, you have a very good chance of breaking off one of the mounting points since the torque won't be distributed to the entire housing. I've already broken one of the mounting points on my old starter. IMO, it's better to just install it correctly and redo it then suffer consequences later.
Post by: nickmpower on January 10, 2007, 03:25:27 PM
using an unbalanced probalby not even completly flat spacer for the flywheel is not the correct way to do it
I think the clutch should hopefully still disengauge, but i think i should make a clutch stop to prevent the tob from going to far. If your guys pedels go all the way to the floor then it should be fine.
I think i will cut some aluminum plate for a spacer for the starter
Post by: nickmpower on January 11, 2007, 07:58:35 PM
what do you guys think?
Post by: romkasponka on January 12, 2007, 03:20:16 AM
I think steel spacer will be fine too..
Post by: nickmpower on January 20, 2007, 12:40:31 PM
does anyone have a picture of their starter with the m20 gear on it???
Post by: Vladi on January 20, 2007, 06:55:51 PM
Unfortunately no, but i didn't need to make a spacer for the starter.
Post by: nickmpower on January 20, 2007, 06:57:36 PM
and you used a m20 flywheel?
Post by: Vladi on January 21, 2007, 05:26:40 AM
Yup. Car runs fine after 3200 miles of city driving, highway driving, donuts, etc. so i've tested it. :D
Post by: nickmpower on January 21, 2007, 03:24:27 PM
hmmm, maybe something is wrong with my starter then???
