DISCUSSION => General Topics => Topic started by: carlos_cr85 on January 21, 2014, 01:22:59 PM
Title: M42 Engine Problem
Post by: carlos_cr85 on January 21, 2014, 01:22:59 PM
Hi Team
I own a 1993 e36 318is; My question is should be to rebuild the engine I actually got a second one to build one engine from cero. Do you guys think is a good idea since i have the second engine.
Title: Re: M42 Engine Problem
Post by: mabeer on January 21, 2014, 03:29:16 PM
Hi Carlos in having difficulty understanding what you question is.  Is Spanish or Portuguese your first language.  If so post up in one of those and maybe that will help clarify.
Post by: DesktopDave on January 21, 2014, 05:08:10 PM
I'd definitely rebuild the spare motor, if it needed it. I have a spare motor in my garage that needs a good bit of work, I've been thinking about doing the same thing.
Post by: carlos_cr010 on January 26, 2014, 04:05:53 PM
The question it is simple. With the two engine I have should be good to rebuild one??
Post by: DesktopDave on January 26, 2014, 04:43:33 PM
Be aware that there are some changes to the M42 over the years. The cam chain guides, chain tensioner, cam chain cases, oil pressure relief valve and the belt-driven accessories changed over the years. You have an E36 motor, so some of those changes would already have been installed.
Later parts are always better than early ones. Some M44 parts will also swap to the M42.
If I'm making one motor from two, I'd be concerned that the same problems might be present on both motors. The M42 had a few weak spots - early type cam chain guides & tensioner. The thrust bearing is only a half-shell (180 degrees), use an M50 shell to get 360 degrees of protection. Water pumps, plastic coolant manifolds and radiators can be trouble regardless of year. Even mild overheating can be deadly to an M42...cracked heads are common. Be sure the cooling system is in tip-top shape. It must hold 2 BAR pressure.
