DISCUSSION => Engine management => Topic started by: alexxander.foster on September 26, 2013, 06:05:21 PM
Hello!
I'm new to this forum so forgive me if I breech protocol.
I've been having stubborn idle issues on my 92 318is, so I decided to take a peak at my DME. To my surprise I found three capacitors were burned pretty bad. The capacitors are a part of the following circuits:
- 12V supply (pin 26)
- DME relay (pin 54)
- DME relay control (pin 27)
I'd like to repair this, but I need to know what their part numbers are so I can find out what their capacitance values are. Would some kind soul be willing to take apart their DME and snap a close up picture for me? I need to know what the letters read so I can figure out what capacitor value each one is suppose to be.
I need a picture of the left, bottom side of the board near the header.
Any help would be greatly appreciated! Thanks!
I might have one already opened, let me check & see. It's from an E30, they should be similar if not identical.
Fantastic! Thank you for checking!
Here you go:
http://s729.photobucket.com/user/desktopdave/library/Projects/175%20DME (http://s729.photobucket.com/user/desktopdave/library/Projects/175%20DME)
LMK if they're OK.
That'll do nicely! Thank you very much! Parts already ordered.
