DISCUSSION => Engine + Driveline => Topic started by: ChItalian1027 on September 24, 2013, 10:20:00 PM
Are there in any NASA spec e30 guys on here? If there are, can you guys tell me what you guys are using for your intakes? Just curious because I want to go into NASA GTS1 with the e36 and need to know what is legal for the intake manifold. I want to know if you guys are using ITBs or if you are still using the DISA valve.
Thanks
You have to use the stock airbox and an M20 engine for spec e30, so I would guess no ITBs.
NASA GTS is completely different than something like Spec E30.
OP, what are the rules for GTS1 for the engine?
Thanks for the help guys!!
Here is a link to the GTS rules:
http://www.nasaproracing.com/rules/gts_rules.pdf
