DISCUSSION => Engine + Driveline => Topic started by: loganwept on September 07, 2013, 11:37:10 AM
Title: M42 won't start after throwing a code
Post by: loganwept on September 07, 2013, 11:37:10 AM
Hi so I was driving my e30 to Oakland airport and it was fine. On the way back it started losing power. It got to the point when when i was on the freeway flooring it going 55. It started hesitating and throwing a CEL. I was almost home when It started bucking and would barley go from a stop. I died in my driveway. I got a stomp test code of 1222. And it would still run just roughly.
I cleaned my ICV my AFM and my throttle body and then it wouldnt start at all... And was throwing a 1215 code
Plugs looked a little blackend from carbon and was giving symptoms of dead fuel pump so I replaced that as well as my AFM still nothing. Still threw the 1215 code. It Will turn over and seem like its gonna start for about 3-5 seconds then die.
I unhooked the battery and then the code stopped appearing but it still acts the same.
I have a new o2 sensor.
New plugs.
New fuel pump
New/used AFM
Thanks in advance and sorry for my scatter brained ness
Title: Re: M42 won't start after throwing a code
Post by: DesktopDave on September 07, 2013, 01:47:22 PM
Did you run a fuel pressure test?  Could be a weak FPR.  IIRC a 1222 is the DME telling you the O2 sensor is out of range for over 10 seconds.  Most likely the whole system is OK, just fuel delivery problems.  I'd also be checking for fuel leaks, especially those little PITA bits under the intake manifold and at the fuel pump hoses.  Also verify that the FP contacts haven't broken inside the socket at the fuel tank...seriously, LOL.  Had that happen on my 633CSi last year.
Did you check the main & FP relays?  Pull the FP relay and use a bit of wire to jump socket contacts 30 & 87.  Then see if it runs better.
Also check resistance on the crank sensor and give it a good cleaning; you should see 640 ohms or so.  If that sensor isn't giving a really good solid reading to the DME, it'll start cutting out the FP relay.
I had this happen to me just a week ago - my 745i would barely run.  Since it's a Euro model - no CEL.  Turned out the entire fuel system was OK, the relay was bad.  I'd assume those little internal contact pads wear out after 20 years of carrying power.
