DISCUSSION => Engine + Driveline => Topic started by: wake74 on July 27, 2013, 04:44:28 PM
Title: Code 1215 - Surging Idle after performing a bunch of maintenance
Post by: wake74 on July 27, 2013, 04:44:28 PM
The new to me 95 318ti (M42) had a bit of a rough idle, and lots of obvious deferred maintenance.  This weekend, I did the following:
Took a bit to get the car to start but it won't idle smooth at all.  Surges from around 500 to 1,000 RPM.  Runs above that, but not too smooth.
Engine code is showing a 1215, which is Mass Air Flow Sensor.  I didn't do anything to that at all.  The MAF is plugged into squid. No engine codes previous to this tear down.
Thoughts?  After all that work, I was hoping to have a better running car, not a worse one.
Thanks!
Glenn
Title: Re: Code 1215 - Surging Idle after performing a bunch of maintenance
Post by: monty23psk on July 27, 2013, 07:46:06 PM
Sounds like intake leak, its possible one of the gaskets for the intake did not get a good seal.
Post by: timmy.chisholm on July 30, 2013, 09:40:29 PM
You can find any vacuum leaks by spraying around with a can of brake cleaner. Your engine will increase in RPM if you  spray the location of the leak (if there is any). Maybe you just forgot to tighten one of the clamps around a hose, happened to me leading to the same results.
