DISCUSSION => Engine + Driveline => Topic started by: hootis on April 21, 2013, 04:20:31 PM
Title: mounting an external oil pump
Post by: hootis on April 21, 2013, 04:20:31 PM
Has anyone don this? im in the process of doin an all out NA build and im going dry sump with external pump. I was just wondering if anybody has done this and if anyone knows of anyone making brackets to mount the external pump. i was thinking of getting rid of my ps pump and ac compressor and mounting the pump where the compressor once set. any help would be appreciated.
Title: Re: mounting an external oil pump
Post by: romkasponka on April 21, 2013, 05:27:00 PM
There is lots of dry sump pumps manufacturers so in this case you need all kit: pump and bracket.
Post by: hootis on April 22, 2013, 08:16:03 PM
Ok so I found the pan on gt technic but if anyone knows the location of an entire kit that would be helpful
Post by: danlolasdad on April 22, 2013, 08:42:23 PM
Will you sit the engine up straight custom inlet and exhaust mmm tidy 8)
Post by: dsm2002 on April 22, 2013, 11:30:37 PM
I am currently doing this. I have a ARE pan which I purchased through Donald at GT Technics. I can highly recommend contacting him as he can assist with pan and design of the layout, etc.  I initially looked at setting up on the left hand side (your driver's side) of the engine as the outlets from the sump pan point in this direction. However this means relocating the power steering pump and alternator. While this is not hard, as I am removing the air-conditioner compressor, and I am currently looking at mounting it on the right side in place of the compressor. It seems to be the most sensible, particularly due the the orientation of the pump I have. VAC mount their kits on the right.
I will be mounting my engine upright for greater room for headers. I have had some plates laser cut for engine mounts and made a MDF plate to dummy mount the pump to work out a position to align pulleys.
Here are pics of the sump pan:
(http://i16.photobucket.com/albums/b15/dsm2002/2013-01-30115640_zps5498a4d7.jpg)
(http://i16.photobucket.com/albums/b15/dsm2002/2013-01-30115651_zps54fb13ee.jpg)
I am thinking about this position:
(http://i16.photobucket.com/albums/b15/dsm2002/SCPpumplocation_zps2c7190ad.jpg)
Engine mounting plates:
(http://i16.photobucket.com/albums/b15/dsm2002/M42enginemountplates_zps00acbbc7.jpg)
Post by: hootis on April 23, 2013, 06:10:37 PM
so did you have the mounting brackets made or did you buy them somewhere?
Post by: dsm2002 on April 23, 2013, 07:07:59 PM
I had a couple of sets laser cut
