PAPER OR PLASTIC => For Sale => Topic started by: e3091318is on April 17, 2013, 12:17:39 AM
Title: M42 + More Parts list! CHEAP
Post by: e3091318is on April 17, 2013, 12:17:39 AM
I have instrument cluster trims (around the cluster and lower steering column one.)
Idle control valves (various types let me know what you need)
timing chain case for the M42 (front lower portion)
E36 M42/M44 Valve cover (just sand blasted and hot tanked, looks brand new and ready to be painted)
M42 Cylinder Head (has two small hairline cracks that can be welded, machine shop told me $140 but I bought an entire engine instead)
M42 Cam Shafts (polished and great condition)
M42 valves (all 16)
BMW E36 Fuel Injectors OEM Bosch 280150415 CLEAN (check part number but I believe they fit early model M42 engines without the air tube)
M42 E36 upper and lower intake manifold (selling cheap)
Tweeter speakers (one has the little tabs broken but easy fix and they both work)
Heated seat switches for E30 models
TWO VDO Instrument clusters pulled from wrecked cars.  Not sure what works and what doesn't.  I will give them a test if they don't sell on ebay and I can get my car running.)
BMW crank shaft rear oil main seal gasket housing 1265139 (just the aluminum housing piece)
E36 M42 throttle body
M42 E36 Automatic flywheel (someone can basically have it if they just pay for shipping and a little tip for me)
M42 Crankshaft
M42 Pistons (no rings)
Bmw M42 318I E30 E36 Bosch Starter 1 005 821 506
Message me with what you need any how much you are willing to pay.  No offers are too little.  Just clearing out some stuff.  I put many of these items on ebay for 30 day OBO prices.  Let me know if you want pics or anything else.
Title: Re: M42 + More Parts list! CHEAP
Post by: Matt-B on April 22, 2013, 01:32:05 AM
how much for an m42 cam and some valves? making a coat rack for a friends wedding...
Post by: e3091318is on April 23, 2013, 04:04:03 AM
Haha that sounds cool.  The cams have been cleaned and look great.  Valves are also cleaned but still have some brown wear marks.  Still would look good on a coat hanger.  Depending on if you want intake or exhaust valves and how many you need.  I was trying to sell as a complete set but I am thinking individual might be the way to go since people bend only a few anyways.  I will PM you with pricing.
Post by: Matt-B on April 23, 2013, 09:48:49 AM
ok thanks!
