DISCUSSION => Engine + Driveline => Topic started by: pierre02ti on February 23, 2013, 07:37:40 AM
Putting back engine in place, was not careful enough to identify where each hose was connected. This additional thermostat is not on the regular diagram I found.
Where do the hoses connect? Diagram?
http://realoem.com/bmw/diagrams/e/e/20.png
Thanks
Pierre
You know, I don't recall. That's the upgraded system - it's designed to protect the heater core from high pressure in case the expansion tank fails. I'll take a look downstairs or snap a picture later on today.
IIRC hose #9 comes from the rear cylinder head, hose #6 goes to the upper heater valve on the firewall. Part #20 was spliced into the return hose from the lower heater valve.
