DISCUSSION => Electrical => Topic started by: ironpaws on December 03, 2012, 02:52:34 AM
I read all the info,everyone says you have to pull the cluster to preplace
a 3w bulb.
I laid on my back under the dash,after removing the knee pad federal
bumper underneath,and went up there on the tachometer side and snagged
the bulb with a seven mm end wrench,twisted it and out it popped.
I plugged in a regular interior bulb,1.5 or 3 watt,I forget,and popped it
back in with a long set of needle nose pliers,to start,and gave it the
slightest twist,then reached up while sitting in the drivers seat and
gave it the last forty five degrees needed to lock it in. How nice.
Save yourself oodles of time. The other,speedo side,that looks doable
from underneath,too. I was too pooped to try it. One of those 2AM ideas...
